Something to think about, following the minimum audibility curve for 30Hz to even be perceived (in almost perfect conditions) it has to be 60dB, 75dB for 20Hz. Folks on ASR sometimes say they listen at 60dBC for example, so in other words there are only 2 possibilities:
1. They use copious amount of loudness equalization
2. They have yet to hear sub-bass
Now consider Harman while researching the most preffered in room curve, used a well treated, fairly big room. They had their system calibrated at 84dB if I remember correctly and yet even the most trained listeners required +5dB EQ for bass to bring it to perceptually
flat level. Now what if we want some fun on top of that? What about crest factor? Headroom and thermal compression?
The prevailing opinion on ASR is that people overestimate their subwoofer needs while my personal experience is exactly the opposite. Can your typical 6.5 woofer 2 way play 20Hz at 110dB? Can your typical 10 inch sub do that?
Inb4 experts who never experienced a sub that digs into subsonics without compression/100%thd/annihilation tell me that I don't need it and it's stupid for music
