Noisy Kali Audio WS-6.2 - is my unit broken?
aku
Europe
Hello everyone!
TLDR: I'm looking for Kali Audio WS-6.2 owners to help me find out if my unit is abnormally noisy.
I just got a Kali Audio WS-6.2 subwoofer based on Erin's Audio Corner measurements and recommendations here on ASR. I intend to use it to get a better bass extension out of my system currently composed of a pair of KEF LS50's (non-meta), an amplifier, and a CamillaDSP on an RPi for room mode equalization.
As soon as I powered on my unit I noticed that in positions of the Crossover switch other than "80Hz" (the other two are "LFE" and "External") it generates noise that is clearly audible from my listening position about 3 meters away. I intend to integrate the sub using my existing CamillaDSP setup so I would like to set Crossover to "External".
The noise I'm hearing is definitely generated by the sub because it is the same regardless of input connections - even when inputs are disconnected. Level of the noise scales with the position of the Volume knob, but to render it inaudible I have to move it from its detent at "0dB". This will make system calibration more difficult and fragile, potentially also reducing available headroom.
The noise is annoying in both level (audible from MLP) and spectral composition (narrowband, centered around 170Hz). I measured the spectrum using a Behrigner ECM8000 measurement mic a few centimeters from one of the woofers (1/24 smoothing):
I need to decide whether to return my unit as defective and order another one, hoping it will be better, or return it and keep looking for a quieter sub.
My kind request to current owners of this sub is this: could you please disconnect all inputs from your unit, set the volume to 0dB, set Crossover to "External", power it on, and tell me if you hear anything when standing somewhere close to it. Thanks!
I had exactly the same issue with mine contacted Kali support, which told me to send it back.
Mine is totally silent. I’m literally next to it all day.
Nah i used Amazon return but Kali Support was really nice and wanted to send me a new one if i did sent it to them.
@ninetylol, thanks.
@voodooless, just to confirm: is your Kali sub crossover switch set to "External" or "LFE"? As I said, the issue I'm seeing is only present in these two positions of that switch. When set to "80Hz", mine is also silent. Also, is the volume knob somewhere close to 0dB?
I have mine set to LFE, no noise. I just switched it between all 3 positions and no noise. I would definitely send it back and get it replaced.
@ninetylol , thanks.
@voodooless , just to confirm: is your Kali sub crossover switch set to "External" or "LFE"? As I said, the issue I'm seeing is only present in these two positions of that switch. When set to "80Hz", mine is also silent.
It’s set to external.
Okay, thank you for your replies!
I will return the subwoofer and get a new one. I'll report back once I have the replacement.
Update:
I got a refund for the first unit. I then purchased another one, for the full price (not B-stock).
Unfortunately, the second unit has exactly the same problem as the first one.
I contacted Kali directly for comment...
Update:
thats a bummer. Kali wanted me to send mine in directly to them to look at the unit. they were really curious, as they didnt knew the problem few months ago.
i got the same problem, i returned the unit
Haruko, thanks for the video. This looks exactly the same as mine.
What you tested with noise, I tested with a 40Hz tone generated from REW. I got the same gating behavior, and at roughly the same level: -45dBu.
I will attach a link to this thread to my conversation with Kali.
Well this is interesting. I was just hooking up my 6.2 with a miniDSP, and when I turned off the internal LP filter I got the same issue. What happened with your subs? Did you get new ones, and are they any better?
After a lengthy conversation with Kali support no solution was found.
I decided to keep my unit anyway. I preferred to use Kali in 80Hz cutoff mode than to keep looking for a similarly affordable, performant and compact sub with force-cancelling drivers (I don't think there are any).
The support person declared they will get back to me if/when they have a fix. I don't expect them to ever do that
Thanks! Yeah, I guess I will have to live with that. For me the optimal crossover is 90 Hz so that is close enough. It seems weird the subwoofers are useless in any ther setting though. Why even make it an option?
Hi @aku, I raised the issue with Kali, and they responded quite swiftly and wanted some additional info. Apparently they are working on a fix:
"Thanks so much for the supporting details! I can clearly hear what you were describing, and it lines up with an issue currently being worked on here at Kali. We don't have a fix ready as of this very moment, but I would be happy to keep you posted on our progress."
Reactions: aku
FYI for those that find this thread later, Kali did figure out a fix for this noise issue. My WS-6.2 had this noise issue, and I shipped it back to Kali for service with Kali covering the shipping costs to and from their offices in California.
After I got my WS-6.2 back from service, I don't hear the noise anymore.
Thanks for posting it here.
I'll get in touch with them. Let's see if they'll fix mine too!
What was the turnaround time for the repair if you don’t mind me asking?
I noticed that my WS-6.2 has the same issue when set to either LFE or external, but seeing as how the 80Hz crossover integrates quite well in my particular setup I’m debating whether it’s worth the hassle.
I probably should do it if only for peace of mind, but I always get cold feet when it comes to packing and shipping heavy equipment over long distances.
Great little subwoofer though.
