killdozzer
- Thread Starter
- #181
Yes, that I know. I still don't see why would it be more important in determining what is the preferred upper limit of SPL that members here enjoy listening at? You turn it up to whatever tickles your fancy and just write it down. Also, that's why I proposed a well produced song. Hey nineteen shouldn't be compressed. At least I haven't come by one that is.In some forms of music, there can be significant differences in level with time, as we all know. If we have a speaker that works well at 86 dB, but falls apart after about 94-95 dB, it will do fine provided the level doesn't exceed the 94 dB limit. For something like compressed pop where we are listening at around 80 dB all is well. The speaker sounds great and we are happy. If we are listening to classical music with a number of quiet passages, we are likely to turn it up enough for them to be audible. But when there is something like percussion or crescendo of the orchestra the levels may go up much higher. Say 95-100 dB. Here we are beyond the limits where the speaker can produce undistorted sound, and it will misbehave in some way. Usually a well-designed woofer can cope by just getting to its excursion limits and limiting any further travel in a controlled fashion and it will sound muddy or maybe have some crackle, but tweeters can produce a lot of nasty high frequency harmonics when they are overdriven. This means that instead of the desired awe of orchestral power, we will get lots of unpleasant distortion and noises during those passages as we have exceeded the limits of the speaker. In many ways, its like clipping since these effects seldom come in gradually, but fairly rapidly as we get to the limits of the transducers in my experience. Ideally you want enough reserve to not go too far into the large signal portion of the transducer's response as that is where things start getting nonlinear.
There is no sense in determining the upper volume limit by quiet passages in classical music nor by the short loud burst. I hoped we've ruled those out by saying it's the loudest volume you stick to during at least one album. So, no short quiet passages or short crescendos.
If you rarely listen to pop or such, maybe you could use another music program. But my guess is that you would listen to what ever SPL still comes out clean at the loudest part.
Maybe the loudest part of Carl Orff's "O Fortuna" is long enough and loud enough for you to measure. Just don't turn on your SPL meter during the quiet part because the average will get screwed. Wait for the loudest part, turn it up to your genuine liking and take down the number.
