I doubt it!I tried. They won't. And the sales rep was super rude too. Just so annoyed I didn't want center and wanted a bookshelf. Was not impressed at all.
They sell cabinets if you drop a speaker.
I don't use DIRAC so don't know how you can configure that. But if you want more low end extension on your speaker then I'd put in a Low Shelf parametric filter of +5dB just before the speaker start to roll off. So with your 65Hz@-3dB (roll off), then I'd put in something like Low Shelf at 100Hz, +5dB, Q0.707. So you're basically just artificially lowering the roll off point of the speaker. That would give you a slightly boosted response at 100Hz, more so than normal, but any RoomEQ you do on top of that would bring that back down to your target. So with that filter in place you should get another 20Hz more low bass extension judging by the slope of the roll-off:Just got my R6 Meta.
While it's wide directionality is impressive, but for some reasons, I am not getting any additional low frequency performance (rated at 65Hz@-3dB) compared to the Polk Reserve R350 (rated at 75Hz@-3dB) that it replaces.
Especially during dialog, it's missing the vibration of the human voice's lower registers.
Does anyone know what is the appropriate way to give the R6 Meta some boost when outputting human voices. I can think of:
1. Go to my Dirac Live AVR to bump up R6 Meta curve in the low frequencies zone?
2. Make the Crossover of center channel lower?
3. Both of the above?
4. Something else?
I assume you reran Dirac RoomEQ?Just got my R6 Meta.
4. Something else?
Dirac doesn't have "low shelf" function but I can edit the Center Channel "target curve" for R6 Meta to achieve the same effect that you suggested! Thanks.I don't use DIRAC so don't know how you can configure that. But if you want more low end extension on your speaker then I'd put in a Low Shelf parametric filter of +5dB just before the speaker start to roll off. So with your 65Hz@-3dB (roll off), then I'd put in something like Low Shelf at 100Hz, +5dB, Q0.707.
Logically yes, the Low Shelf will delay the roll off, but Dirac "recommends" 100Hz crossover based on the capability of R6 Meta, so I will be testing a non-recommended crossover of 50Hz or even lower to see if the Center Channel will output the effects of the Low Shelf and still integrate well with the rest of the channels (Front, Surround, Heights) all set to 100Hz crossover.So you're basically just artificially lowering the roll off point of the speaker. That would give you a slightly boosted response at 100Hz, more so than normal, but any RoomEQ you do on top of that would bring that back down to your target. So with that filter in place you should get another 20Hz more low bass extension judging by the slope of the roll-off:
Thanks for quoting the graph! I mentioned R6 Meta rated at -3dB at 65Hz, because that's what their marketing says on KEF's page:![]()
However, how come you're saying your KEF R6 is rated at -3dB at 65Hz, because in the above graph you can see that it's already at -6dB at 70Hz - in reality 65Hz is at -30dB!
I tweaked Dirac's target curve, will be testing the "Low Shelf" effects at different crossover for R6 Meta (eg. 50Hz, 80Hz, 100Hz) to see when the boost is most audible and if it still integrates well.I assume you reran Dirac RoomEQ?
Since this is listening test, I will need some time but for sure I will report back!
You definitely need to rerun RoomEQ to properly EQ your new speaker!
Hello
I tried Kef R2C last year to match with my Kef Reference 3 front speakers.
I didn’t keep it a long time because i wasn’t satisfied with it.I felt that male voices seemed like they stay inside the box. As they were muffled.
Do you feel the same issue with the R6 Meta as a center channel ?
I tried the Non-Meta R2C.Did you try the Kef R2 Meta or the non-Meta R2c?
Is the Reference 2 Meta in your budget?
I'm looking for the R6-Meta that’s why I wish to know if it have the same issue.
Thanks for your reply.My mains are Reference 5s NM. I used to have the older Reference 204/2c previously. I tried:
- R2c NM
- R6 Meta
- Reference 4 NM
- Reference 2 Meta (my current center)
I found the R6 Meta definitely to open up more than the R2c NM, and obviously the larger woofers allow a comfortable 80Hz crossover, but the Reference centers really opened up another dimension. So yes, the R6 Meta is better, but you might want to save some money for the Reference 2 Meta (good dealers will give you a decent discount off MSRP).
Can you demo the R6 Meta? I know crutchfield allows this for example. What's your processor?
I Dreams to have Reference 2.But i cannot find a used one to have decent price.
I'm living in France and it is difficult to have discount.And to demo with crutchfield.
I can have around 100/150€ discount on the R6-Meta but no more.
In your opinion the R6-Meta does not have this "Muffled sound" issue the R2C NM have?
My AVR is Denon 4500H
Thank you.I'm a bit surprised that the R2c has a muffled sound. I wonder if that's an EQ issue? Either way, the R6 Meta is a definite improvement, and if you can afford it, it will be a much better pair with your Reference 3 speakers.
They do. I asked.I doubt it!
You have no issues driving these speakers with your 4500??Thanks for your reply.
When I am in HT I configure crossover so Denon don’t drive speakers in full band.You have no issues driving these speakers with your 4500??
Great!After struggling with R6 Meta for a bit, as suggested by some forum members, I added a Low Shelf and found the ideal XO of 50Hz using Dirac Live, now it is finally living up to its promise as the most amazing center channel ever made for mortals (aside from the Reference).
Vocals are being delivered in such clarity (female) and weight (male) across multiple seating locations, it's simply incredible. After struggling with my home theatre sound for 20 years, now it's Done done.
So glad I did not cheap out on R2 or other center channels.
