Can we put it in the first page ( if one's looking on a phone ) so after first paragraph at the top.I put a link and note there to new measurements already.
Exactly!They have REW in the RTA mode, which will display pink noise as a "flat" response. (Equal energy per octave.)
If they put REW in the Spectrum mode white noise would display as a "flat" response.
Now comes the question, how did the first one pass quality control? Or, did it somehow get damaged in shipping?So I finally braved the cold garage and measured my purchased sample of Kali IN-8. Here are the results in a more extensive manner per our later tests.
Let's get the most important message out:
Yup. The problem with anemic bass is gone. This makes sense as Charles reported that the tested sample had a bad woofer. Likely that lowered its output capability. Sans the cancellation around 8 to 10 kHz, this is a very smooth response. It shows up just as well in predicted in-room response:
I ran a few tests at different output level to see if there is any bass compression and there was none:
Tested level was third from the top. At the highest level, the IN-8 was quite unhappy (audibly) in attempting to reproduce the very low frequencies but even then, the in-band response was not impacted.
Unfortunately I did not run the levels in the ascending order so the distortion graphs are for lowest output level. Here they are in percentages:
Advanced Measurements
Eye-candy Speaker Measurements
I drilled down into the soundfield (all up wave front from the speaker) at crossover frequencies of the woofer to midrange and midrange to tweeter:
The microphone is at the tweeter level so naturally the loudest sound is coming from the woofer so below the "nref" axis. We have one unified speaker instead of two distinct ones playing their own tunes which is what we want to see.
Same story repeats in the transition between the midrange and tweeter:
So boring in a good way.
Measurement Accuracy
Here is the polar plot for the highest measured frequency of 20 kHz:
This produces the most elongated measurement allowing us to see if it peaks at 0 degree. And it essentially does. I am not taking a protractor and poking a hole in the tweeter to align it with the microphone.So this is as good as it gets.
Conclusion
Seems like the mystery is resolved. The Kali IN-8 is indeed a well-designed speaker when it is not broken.I am relieved I did not like the sound of the broken one.
Now someone needs to buy this speaker from me so that I can use the money to eat lunch tomorrow. No, it is not at a discount. It is the only Kali IN-8 with $100,000 measurement data!
I will link the review post to this one.
Preference RatingHere is the spin data.
What about "hiss"?Conclusion
@amirm did not publish them.@MZKM It might be worth having both the original IN-8 measurement as well as the new one in the master spreadsheet. Just add something like "(DAMAGED)" to the speaker name to differentiate the broken one. I think it could be interesting to see how damage can affect a speaker's preference score.
Quick question, it's not covered in the manual, so are these intended to be used with full toe-in (aimed to the listeners ears), or used facing straight?Apologies for the delay. We wanted to understand what happened, We were able to get the loudspeaker you reviewed back from our dealer since there are not many returns, but we just received it this week. It was immediately evident that the loudspeaker is indeed damaged. Perhaps you missed it, but the surround is pulled away from the frame as can be seen in the picture you took (attached, circled).
From another angle, this is what it looks like.
Even with the damage, I was not able to reproduce your measurements unless the speaker was pushed all the way into limit. I'm only using a portable rig on ground plane, so we are having this sample and another from inventory sent to an independent lab for full measurement set. We will publish their results.
It is hard for me to understand how a clearly defective loudspeaker would somehow slip through 100% end of line testing including visual inspection rub/buzz, frequency response, and distortion test (3 separate stations). At the same time, I never would have anticipated that the surround could come loose during shipping / handling, as it is captured between the rear mounted frame and the baffle. I will be initiating 8 discipline problem solving action in order to fully understand how this could have happened. Rest assured we will diligently work to make sure this odd defect doesn't happen again.
Best regards,
Charles
