JBL Stage A130 Review (speaker)
Jmudrick
I never listen to any speaker in the garage, cold or otherwise. The measurement gear is in the garage and it removes the effect of the garage so it is not even material there. All listening tests are performed where I listen to my systems: my 2-channel far field and 2-channel near-field. It is an open space requiring lots of SPL to fill it. But it is no garage. And it is at normal living temperature.
Duly noted , thanks.
VipinS
I never listen to any speaker in the garage, cold or otherwise. The measurement gear is in the garage and it removes the effect of the garage so it is not even material there. All listening tests are performed where I listen to my systems: my 2-channel far field and 2-channel near-field. It is an open space requiring lots of SPL to fill it. And it is at normal living temperature.
Hello Amirm.. can you please check out my post and reply . Thank you in advance . I took my decision after seeing your review of stage a130 here . https://www.audiosciencereview.com/...ile-home-theatre-5-1-setup-help-please.18483/
witchdoctor
Not looking forward to your review at all. Probably will have to dig in my pockets again.
Yep, I started with the 230's,then added the 225c center, then the 210 surrounds, the 250P sub and finally 4 of the control CRV as height channels in the man cave. I just added one item at a time and tried to catch them on sale when I could:
boselover61
I picked them (the arean pair)up on clearance for only $50USD new.
Very nice smooth sound with a little grain in the trebble and fatter bass than A130.
Essentially I remember initially thinking I'd keep them but never really fell in love with them.
Bear in mind I try a lot of speakers and design them as a hobby so I often don't keep them even if most people would be more than happy.
I'd say give them a chance. My opinion is that they sounded worth recommending people try them.
At that time I was also running the Polk Lsim703 and the NHT C3, so much pricier gear.
I kept the polks for about 1 year (very rich sounding speakers)and the C3's (very detailed speakers, perhaps edgy)for a couple months. Both of those speakers lost to the JBL 530's which I will never sell.
What do you use to power your speakers? I only have a 20w amp but it the bass is absolutely nutty on the Stage A130. With a little more power it should be very good
VipinS
I glanced at that thread earlier. As noted by someone, don't get Control 1. That is not a proper speaker for your application.
I am torned between Polk t15(110$), Polk owm3 (180$) and Jbl a120(215$) .
Recommendation ?
Recommendation ?
Not without testing them all. I highly encourage you to stay with speakers that we have tested. Anything else is a random dart thrown at the board....
VipinS
Have you tested any of these ? Any other recommendation ?
witchdoctor
A matching speaker in the series from the same design team is not a random dart. Mixing speakers from different brands in a HT setup I would agree is more of a random dart.
Thanks ! Is it safe to assume a120 would pass your tests simply because a130did with flying colours ?
It is a different design but from a company that knows what it is doing so yes.
VipinS
I will have to extend my budget a little bit I hope it will be worth it :)
Thank you .
Any suggestions on subwoofer ?
Svs ,hsu,rhythmic are not options here .
Polk audio hts 12 vs Jbl a120p ? How about Klipsch r120sw?
stunta
Boston, MA
Yes and thanks to this review, I now have the A130s in place of the ATC SCM7s for surround speakers. At this rate, I will soon want a "Certified by ASR" sticker for my entire system.
sweetchaos
The Curator
BC, Canada
Thank you .
Check out Erin's youtube channel, where he talks about his subwoofer reviews, and his spreadsheet, where he currently shows his CEA2010A/B results.
Lots of threads on ASR talking about budget subs. Link. Link2. Search the forum for more.
