The waveform is clearly distorted and has plenty of harmonics and noise:
And i assume so is the power at
the_surf_doc all the time.
but only "occasionally made it through to my power amps"
so maybe distortion and harmonics on the AC (in differential mode) are not the problem
Maybe there is also Common mode noise and maybe if its only "occasionally" and not repetitive so a screenshot from FFT might also not be a proper way to capture this.
What is clean is the DC output inside gear.
And here we are... someone is having expansive amplifiers "occasionally" having Audible noise from the AC line coming trough.
not all the time. so the usual distorted mains is not the problem.
Yes, there are some broken audio gear that let more noise through but that is why you should read my reviews of equipment before purchasing.
And what of your tests would show us if an amplifier is "broken"?
How do you know what kind of occasionally EMI/EMC he is experiencing and with what amplitude.
I don't see any tests for Amps on CMRR or any on how they Handel EMI/EMC.
Or hold up time and brown out tests.
