Cable shield capacitive current will remain an issue.
The application here is audio. I am measuring output of such devices up to 90 kHz which is way, way beyond audible limit. What possible reason would there be to measure higher frequencies?Measuring and quantifying power line noise is an undertaking needing a wide band spectrum analyzer and an interface to prevent the junk on the power line from frying your expensive analyzer.
They don't help. Sadly many people go and buy them only to find that it does them no good. You need to use balanced interconnects to avoid ground currents to become part of the audio signal.However in a network of audio devices you can find chassis leakage and noise currents between the boxes that can get into the audio. Line filters may or may not help, it all depends.
I have done that many times with non-polarized two pin AC cables and switching power supply. In rare, very rare cases it makes a tiny difference. In vast majority of cases, it doesn't change a thing as the leakage and hum is due to other sources.The old Japanese thing of flipping the polarity of the power cord does have some validity, due to this leakage issue but was always a real PITA to deal with.
Your speakers and headphones have no ability to play RF. And neither does your ear. In rare cases, RF can get demodulated but if it does, then you hear that interference. This has nothing to do with the reason people buy these devices. They buy them without any indication of problem.It's not the audio output that needs the wideband tools, it's the power line itself. And some power supplies pass the rf. through to the internal electronics which do not necessarily evidence as a simple output.
There is nothing "on topic" in your post. I can't believe how much the plot is lost here. For the tenth time, audiophiles buy these products to improve fidelity of their systems thinking it improves direct fidelity of the sound they hear. They are not worrying about ground loops, audible artifacts, etc.On topic, besides the differential RF noise signal test @1audio suggested, another nice test is applying common mode RF cross current through the device, entering at the mains/supply/USB/etc connection and leaving at the audio connector "grounds" or whatever path the RF might take. Basically the same test as done for EMC (see Ott's "Electromagnetic Compatibility Engineering" for details)... were the go/no-go criterion is not very well defined for audio devices, ususally the interference's effect is not actually measured on audio outputs but rather a subjective judgement is made: if the modulation frequency (3kHz, typically) can be actually heard in a typical use case, then fail.
I have not read through all 27 pages in detail so perhaps I missed someone linking to this recent review. This must be some kind of record...
https://audiobacon.net/2021/08/06/the-worlds-best-audiophile-linear-power-supplies/
I tried to point out that products tested for FCC and CE compliance usually won't have issues.
I think I should build a different probe, following that model:
@amirm, since you’re online, any thoughts on the Cardiac Electrophysiology data and how that might translate into moving coil phono measurements?
The big difference is that in electrophysiology, they are looking at visual waveforms that are amplified. May have no bearing to what is audible if that waveform was converted into audio.
But the voltages they talk about are in the range of MC amplification…
here comes how main voltage looks in London city UK , outlet in home , all of these harmonics IS in your audio system .
