What would you call the mains from Amir which was also used ?
Quite "normal" spectrum of mains line as I see it here as well.
The B&K noise simulator is only able to source 300VA of power. For a 120V system, that's only 2.5Amps in a perfect world. Power amplifiers require much more than 300VA to function, hence Amir's test on line-level equipment like the Topping HPA and the tube HPAs. The 300VA B&K noise simulator already costs about $5,500. I shudder to see what a full-blown 3000VA would cost, able to source 25Amps @ 120volts.
I'd like to see some huge beats in between 5k and 100k, and listen how sensitive amps input stages, buffers and preamps would render those.
Why, what would that simulate in real world applications ?
See my earlier post, if anyone is looking for a test bed for this type of study I’ve got it right here!A fridge motor startup. Fridges being nowadays common in most houses.
you’d think that this was a highly conclusive test that had revealed that there was little to no effect from erratic mains on audio kit by the conclusions being gathered. Let’s be honest shall we, it’s not.
it does however demonstrate that the Topping a90 is a very good headphone amp (and bloody good value by the looks of things)
Everything will be rectified and end up as DC which in most equipment is regulated after smoothing.
Edit... Yeah, I assume if one has a DAC, he has a fridge close to it.
Those spikes usually are partly common mode and differential mode.
Topic being "& noises". I do not see this in the test Amir did run, he only added some distortion to sine.
Earlier, I added Amir shall run other tests, with noises (5Hz bursts) in diff and common mode.
Attached being representative of what is occasionnaly flowing in 0V/ground/earth rail in my audio setup.
No... that was only in the case of the 'dimmer' test. The mains was also used which has a 'normal' amount of distortion and noise.
You must not have read a fraction of the test then.Topic being "& noises". I do not see this in the test Amir did run, he only added some distortion to sine.
I then replaced AC mains with BK Precision lab AC generator which produced substantially cleaner AC -- better than anything you hope to do with any noise filtering.
I did. Relative to Lab AC, the regular AC source has added noise. Both produce identical performance.Add noise
