staticV3
- Joined
- Aug 29, 2019
- Messages
- 8,109
- Likes
- 13,041
The LDC-2 Classics is a very easy to drive headphone. The Zen Can will have no problems with it.Hi all! I have this amp. How it work wit LCD 2 classic? Thanks
I'm no electronic engineer, but how can a device powered by a 2 prong wall wart be grounded? Or in other words how can an appliance that's not connected to ground be grounded?Anyone have any idea why balanced connection causing a ground loop ?
I use RCA cables between zen dac and zen can too. It dissipates the 4.4mm bal interconnect buzz. I find it weird that RCA has no issues but BAL has issues. It should be reverse lol. I bought this 4.4mm bal cable from aliexpress. Can it be the cable ?I'm no electronic engineer, but how can a device powered by a 2 prong wall wart be grounded? Or in other words how can an appliance that's not connected to ground be grounded?
My understanding is that this device has a common ground in the 0v rail, but the device isn't really grounded.
I grounded mine connecting a 3.5mm double male cable between my computer and it (there's other ways equally cumbersome), and I don't know how that works or why it works, since 3.5mm isn't grounded connection either, but it does.
Definitely weird. And no, I doubt it.I use RCA cables between zen dac and zen can too. It dissipates the 4.4mm bal interconnect buzz. I find it weird that RCA has no issues but BAL has issues. It should be reverse lol. I bought this 4.4mm bal cable from aliexpress. Can it be the cable ?
Don't think so, you could buy the ifi 4.4mm interconnect on Amazon if available, and return it if it doesn't solve the problem, or even if it does since its price is outrageous.I use RCA cables between zen dac and zen can too. It dissipates the 4.4mm bal interconnect buzz. I find it weird that RCA has no issues but BAL has issues. It should be reverse lol. I bought this 4.4mm bal cable from aliexpress. Can it be the cable ?
That is.. also weird. These Zen CANs seem to have some seriously odd designAlso, did you notice any output volume increase going from RCA to bal? I bought a topping d10bal thinking I would get some more output volume but I got the same I had from RCA.
Yep no volume increase. That surprised me too. RCA and BAL same loudness despite being 2v vs 4v. I guess they are both 0db unity gain.Don't think so, you could buy the ifi 4.4mm interconnect on Amazon if available, and return it if it doesn't solve the problem, or even if it does since its price is outrageous.
I'm no expert but maybe input impedance causing this ? But 3.5mm jack is 0dbfs too.
Inputs 4.4mm Pentacon BAL
RCA L/R Socket SE
3.5mm Jack SE4.0V nominal @ 0dBFS, 24 kOhm Zin
2.0V nominal @ 0dBFS, 1 MegOhm Zin
1.0V nominal @ 0dBFS, 1 MegOhm Zin
Actually, it would mean that SE in has +6dB gain to be equal to BAL's double voltage input. Either that, or the balanced input ignores half of the signal which would be false advertising and dishonest.Yep no volume increase. That surprised me too. RCA and BAL same loudness despite being 2v vs 4v. I guess they are both 0db unity gain.
It should have some kind of mechanism to match all the inputs at output level. I don't know if this makes sense lol i'm confused.Actually, it would mean that SE in has +6dB gain to be equal to BAL's double voltage input. Either that, or the balanced input ignores half of the signal which would be false advertising and dishonest.
Unity gain would have the balanced be louder than the single ended input..
In Amir's test at 300ohm 0db gain, SE out have 13mw, BAL out have 52mw. This should mean 2x2=4/300=13, 4x4=16/300=52 but the loudness is same?
Yeah same but at 33 ohm at 0db gain, the difference is same. SE: 116mw BAL: 463mw. Their max power output is same but SE reaches that at 12db gain, BAL at 6db gain.@32ohm both channels have the same output, I only have low impedance headphones ATM, so maybe with 300ohm HP the output difference is noticeable. I wonder if IFI limits the potential of the amp to such extent to keep it in class A mode.
Discussion is around the loudness/gain, not max capability i think. Unfortunately i don't have any headphone to try balanced right now buthere's a graph to explain what I mean:
In yellow is Amir's single-ended 33/300Ω data, red the balanced 33/300Ω data, and in blue his balanced load sweep data.
In all three cases I added a fake 150Ω data point which just mirrors the 300Ω results he got. It's unlikely that voltage will drop going from 300 to 150 and leaving that out would've presented unrealistic graphs due to linear interpolation.
Still, take that with a grain of salt as that 150Ω data point does not represent measused values!
Also unfortunate is that Amir's 33/300Ω power data does not match his load vs Vrms vs distortion data. That's because he does his load sweeps at a really low resolution (high step size).
Nonetheless, you can see that at ~32Ω and below you won't get any more volume out of Bal than out of SE. It's only at higher impedances that the Zen Can's Bal out can stretch its legs.
Don't know if this has anything to do with anything. Guess you know this, but the RCA of the Zen dac outputs 2.1V in fixed and 3.2V in variable mode. Switching to the variable mode it gets louder by a margin.Yep no volume increase. That surprised me too. RCA and BAL same loudness despite being 2v vs 4v. I guess they are both 0db unity gain.
This is what they say in product page:
Edit: They also say this maybe relevant:
- SE inputs (1M Ohm) ensures loading of the source so always in Class A operation
Yes.Is this because of the higher voltage going in to the Can?
I would guess so but if the CAN's input RCA is nominated at 2V should this be avoided?
Max. Input | Balanced RCA 3.5mm | 7.4V RMS 3.8V RMS 1.92V RMS |
It should be louder with BAL too. Use 4.4mm interconnect and try variable mode.And why would it be louder with higher voltage in RCA SE and not from the BAL 4.4mm.
But didn't you say volume was the same from RCA and 4.4mm? Or did I misunderstand something?Yes.
This is max input voltage so you can increase it.
Max. Input Balanced
RCA
3.5mm7.4V RMS
3.8V RMS
1.92V RMS
