If you have a circuit breaker with a differential protection (generally 30mA) and the circuit breaker is triggered, then yes, it means that a least 30mA are leaking to the ground, could be more.It suggests some kind of short to ground but I'm not an expert.
With a multimeter, test the continuity between ground/earth and phase, then between ground/earth and neutral. If there is a continuity, then there is a short to ground somewhere.
In your picture actually the chassis doesn't seem connected to the earth of the power plug, that's what triggers the circuit breaker for me.
It's far from sure that the unit is original.That photo is from the ICE manual.
In mine it is connected, as you can see in the previous post.
Is the ICE surely original? Where did you buy it?
I plan to buy it from aliexpress
https://a.aliexpress.com/_dSSXlyY
I know it's fake, it's on my budget though, so i like to compare this with topping pa3Attention on Aliexpress.
Read this 3ad and find out that it's probably a fake.
How can you tell if a fake works well?So che è falso, è nel mio budget, quindi mi piace confrontare questo con topping pa3
