ishmeister
S8 is currently on sale on Amazon UK. Black Friday discount + additional £20 for prime members bringing the price down to £59.
Interesting. Perhaps the 3.5mm input is somehow better protected against grounding issues, that is if it's really no issue with the cables used.using 3.5mm input in my amp, so dropping RCA - solves all the issues, there's no noise in any scenario above. I have tried playing with running laptop on battery vs charging, changing power profiles etc. but to no effect.
I don't understand why RCA cause troubles? Tried 3 different RCA -> 3.5mm cables (which work well with other devices anyway) and same.
The amp is JDS labs Atom, I had grounding issues with other DAC... but on 3.5mm atom's input. Go figureInteresting. Perhaps the 3.5mm input is somehow better protected against grounding issues, that is if it's really no issue with the cables used.
Ground loop troubleshooting, always fun.... good thing you've found a work-around though!
Does anyone else have issues on Android? It works on and off on my Samsung S20+. Firstly, there will get to a point about an hour or so in use that the phone disconnects and I lose audio on the phone. Reconnecting the S8 does nothing. Occasionally, it freezes/reboots. And also if I disconnect the device and I try to receive calls or anything, the audio will not play through my phone and I need to reboot.
I have tried it on my PC and I have no such issues. I updated the driver a few months ago and tried it again and had the same issues. I also tried with both USB debugging mode on and off.
I want to look at the Hidizs S9 as a possible replacement, but if the software issues are still around then I am less inclined to buy it.
About to buy the Sonata HD Pro, 2 questions:
- Any issues with plug and play on Windows 10? I can't install drivers on my work laptop. Don't need ASIO or anything, just using for spotify premium.
- Any issues with using on Android phones (galaxy s10) without UAPP? Again, just using spotify.
Thanks
Thanks can I ask where you bought it second time?I did get a faulty unit from the official store on Aliexpress. Seller asked me to install driver and all that but the fault is probably the hardware. Subsequently, however, I bought it for cheaper from another seller and just tested it. Now this unit works like a charm. No need to install drivers on Windows 10 using Spotify. Works with zero pops. So, I think I just got unlucky. Most don't seem to experience much issue judging by the high ratings of most customers. Still pops when I change tracks or adjust song progress bar on Foobar tho. But that's very minor.
Shopee https://shopee.sg/TempoTec-SONATA-H...e-Amplifier-adapter-DAC-i.66630848.5134555106Thanks can I ask where you bought it second time?
Yup doesn't ship to me. Almost same price as Ali though so I will take the risk!Shopee https://shopee.sg/TempoTec-SONATA-H...e-Amplifier-adapter-DAC-i.66630848.5134555106
I don't know if it's available in many other countries. Prob SEA only?
I think it's fine to order on Aliexpress too. Just got unlucky.
Great news all around! Thanks for reportingI bought the Sonata HD Pro a few weeks back in China, so YMMV.
There's popping sound when I change tracks on Windows 10 desktop, then I updated the firmware to 3.0 and installed the driver under the Sonata HD section on their homepage. Everything working flawlessly since.
Also working fine on android devices, plug and play, with spotify.
FWIW, it's been flawless on Macs running Big Sur too.
Hi,
I bought a S8 from the official store on Dec. 2nd and I don't see any progress with the parcel still stuck in China. Does anyone have the same experience ? I chose normal shipping and true they announce long delivery times via this shipment method...
Cheers
Greg
