Help! TRUTHEAR x Crinacle Zero tips fall off in ear.
Bacchusoo7
Hi Friends,
I have a pair of the TRUTHEAR x Crinacle Zero and tips keep coming off in my ears. It started with just the right one occasionally and now it happens on both, a lot. I can get them out, so it not like it requires a doctor's visit or something but it is certainly annoying and inconvenient. I don't have a lot of experience with IEM but I have been using them a fair amount lately. Am I doing something wrong here? Does anyone else have this problem? Any thoughts about a solution? Thank you.
markanini
Scania
Submerge the tips in boiling water for one minute and leave them to dry for a few minutes. They will shrink back to their original size.
raif71
Hi Friends,
Hear's a tip, perhaps you need new tips ? :)
poopy
Hi Friends,
This is a common issue since the tips provided are crap. Buy some spinfit eartips. Problem solved.
VMAT4
South Central Pennsylvania
CP100, I believe.
B
Bacchusoo7
Wow! Thank you! I will check out the CP100s asap. I wouldn't have known where to begin otherwise. Much appreciated!
VMAT4
I'm sorry, the right size is CP155.
poopy
I currently use some spinfit W1 size L if I'm not mistaken. You can buy spinfit products from Amazon
poopy
CP 155
MaxwellsEq
I had the same problem (and so have other people as recorded in the Zero review thread). The Truthear medium tips were the best fit for me, so I bought Spinfit 155 medium tips, but they are too small, I should have bought the larger tips.
