Google Nest Audio Speaker Review
Rate this smart speaker:
    Votes: 3 1.4%
    Votes: 17 7.7%
  • 3. Fine (happy panther
    Votes: 112 50.7%
    Votes: 89 40.3%
It was kindly drop shipped to me by a member.
Thanks to this member and for your testing of this Amir. Surprisingly good for the size and price... some more teardown pics;
More detailed;
JSmith
Shouldn't there be an explicit category for these wireless mono lifestyle gimmick "speakers"? They cannot be used like conventional (active or passive) speakers.
You still need a power cable so what does that single-use-case-only wireless stuff brings to the table? Why didn't they include a battery to make it really stand-alone?
The construction looks nice but there is one thing I came to detest from experience, the foam wraps around the cables. The foam tends to disintegrate after a few years and the residuals will make funny noises... but by then the speaker will likely have become obsolete or broken for other reasons.
You can set it up like a soundbar or stereo system connected to your TV over Bluetooth. We have one of those "gimmick" speakers connected to our living room TV this way. When we turn on the TV, it automatically connects to the speaker. Our TV sits on a wall-mounted shelf with enough space behind it to fit the speaker. It’s not a HiFi setup in this configuration, but it’s a hundred times better than the TV’s built-in speakers.
Wonder if a version 2 is on the horizon soon as this has been out for a number of years. They seemingly put a lot of r&d into this and got good results. If they were able to squeeze out a little bit more performance and actually made it usable with an analogue and/or digital input, or with at least minimal latency when used wirelessly, this would be a top product.
Ideally, the switch should physically disconnect the microphone so no hack could reactivate it.
It will be a proper switch that physically cuts the electret mic feed.
Yes, but apparently it's unreliable. Quick Google suggests that they had a solid implementation, but it was too close to Sonos', they threatened a lawsuit, and the new implementation is bad.
That's a shame... I had fleeting dreams of a cheap surround system with 5 of these and a chromecast connected sub for an entry into surround music, but if connecting two is iffy, I can't imagine that a surround system is going to work. Still, it can't be too far away...
Not my experience. It works flawlessly.
I've had no issues with my pair of these working perfectly as a stereo pair as well. I was shocked with how decent these were when I got them up and running.
As known already from other measurements they are great performers with also fantastic cabinet material, kind of little bargain Genelecs.
Would be interesting to find the reason of those interferences in the tweeter region, maybe diffraction from the screw holes?
I would like to see some measurements with those covered with some tape.
Its -3 dB point is 85 Hz whereas the Google Nest Audio is 60 Hz. That would make a considerable difference in the perceived audio quality.
Trying to come up with something in that price bracket. So far that's all I can think of that has pretty solid measurements.
My guess is the front grille:
