Genelec 8341AWM paired with MiniDSP SHD
Sparky
Sparky
Manchester
Jim Matthews
Taxachusetts
Spdif out carries two channels of data, per MiniDSP manual.
You must assign the channels in the Application, on a separate PC.
(Dunno if it works on MAC.)
This configuration is saved to the MiniDSP.
Sparky
Sparky
Manchester
Ok, So I have just spoken over the phone to a minidsp re-seller and they've confirmed that I cannot output anything from the STUDIO version to my minidsp 2x4HD which controls my subwoofers.
The only digital input the 2x4 HD has is an optical but the STUDIO doesn't have an optical output.
I would love to get the STUDIO as the re-seller was potentially prepared to do a straight swap between my unopened SHD in exchange for a STUDIO but I don't see how it would work. I still need an analogue input/output for my subs.
I might as well buy the BNC/AES transformer and be done with this saga! :D
Sparky
Sparky
Manchester
I have bought this:
https://www.neutrik.com/en/product/naditbnc-m
As well as the necessary cables to go with it. I feel the standard SHD is suited to my needs and keeps the box count as low as possible.
With the STUDIO, I still would've had to have bought adapters of some description so it really is "swings and roundabouts".
Thank you all for your assistance in this. :)
Pearljam5000
Just an update.
The 8341's are singing beautifully and I've managed to time align my two subwoofers too with the help of a lovely chap over on "AV Nirvana".
Sounds fantastic. :)
Have you compared the 8341A to 8351B?
Sparky
Sparky
Manchester
I haven't I'm afraid but I'm led to believe that the only real difference is in SPL level.
I was initially concerned about the SPL level of the 8341's but those concerns were soon laid to rest when I fired them up! :)
