Hi guys, I’m currently running two Genelec 8350s and loving them. They are currently running off of a Denon AVR4400H receiver. I am looking at selling the receiver and moving to a 2.1 setup for a while. My room is really not optimal for a full surround setup, and I’m listening to mostly music these days with the occasional weekend film. I want to add a subwoofer to the setup to extend the bass from the monitors, and provide that tactile force from films. My room is very small, 30m3 and I already know from measurements the location the subwoofer will go in (under the desk at the back). I am looking at the following options:
Arendal 1S using the Minidsp Flex - £1900
Perlisten D12S using Minidsp Flex - £3600
Genelec 7370a subwoofer using some sort of USB to AES converter for digital audio with GLM ~ £3000
Custom 15” sealed subwoofer using B&C 15DS115, Hypex FA502 and the Minidsp SHD digital for all digital inputs £2000
I think there are positives and negatives to each option. The Arendal option is attractive due to price and confirmed excellent performance. The Perlisten should be a step up from the Arendal, but at almost double the cost will it be that much better? Genelec subwoofer is the least attractive option to me, based on the specs of the subwoofer for the high price, but GLM and digital inputs are attractive. Finally the DIY option, which would allow me to use the SHD digital with Dirac Live correction. This is attractive but I am not a huge fan of DIY so would probably get the boxes built for me which would drive up the cost another couple hundred quid.
To be clear, I am looking for high spl capabilities (around 115db peaks from 20-100hz) and low distortion. I am also considering the Arendal 1V, which seems like it would provide more output than any of the options above albeit in a larger cabinet (which can be accommodated but isn’t ideal). It’s a shame there aren’t more commercial sub offerings with digital inputs, but I’m not sure how much of a benefit this would be given the Minidsp Flex is pretty much transparent anyway.
So this really comes down to the Flex without Dirac and analogue outputs vs rhe SHD digital with Dirac .3 and AES outputs, but I would only be able to do this option with the DIY sub.
Any help is appreciated! Many thanks, Liam
