I used to disable all windows sound effects so it don't do so, a mild thump does occur once it goes out of sleep thoughDo you get a pop or thump sound when windows starts or restarts? It always happens, even if the speakers are on and not sleeping. If I decide to restart windows, then when the computer logo appear, it makes a low thump, then another one before entering the screen where you put your password
I'm on windows 10
I think is related to windows rather than the speakers as they're new basically
I read it could be "sound scheme engaging and disengaging" but dont know how to disable that or change the sound
I wonder if is caused by the fact that I have the Genelec sleep mode on. Unlikely cause I never let them go to sleep. I turn off my surge protector before I go to sleep, then turn it on when I'm going to use the computer in the day. When I turn it on, the speaker do make a thump noise as well, probably from the current waking them up?
That doesn't explain why it still happens when they are already on, but only on windows startup or restart.
