Pancreas
- Joined
- Nov 2, 2022
- Messages
- 481
- Likes
- 96
A powered hub has a separate power supply, while USB data goes over your PC. If you turn off or reboot the PC the hub stays on and there will be no pop (hopefully).
What interface are you using?
Scarlet Solo 3rd gen which is USB powered. As some guy said, he doesn't have this problem with his PC. The issue here is both my PC USB ports and the audio interface that needs power from the computer USB port.
The cheapest solution is to either get a powered USB hub as you said or buy an interface with its own power supply, that only data goes over USB.
My computer monitor has USB ports, but when I connected this audio interface to it, the green light did not turn. It doesn't have sufficient power.
