I haven’t found any - for desktop use, that is.If pairing these with a sub (e.g. 7040 or similar), and just listening at near field distance at moderate volume (i.e. desktop), is there any real reason to get the 8020/30s over these?
should not be a lot of drawback, but the 8020 and 8030 did goes a bit flatter, distortion charateristics should be better around cross over frequency and the directivity is also betterIf pairing these with a sub (e.g. 7040 or similar), and just listening at near field distance at moderate volume (i.e. desktop), is there any real reason to get the 8020/30s over these?
I've been listening to a lot of rock and metal on 8010A s and they sound great with good bass.I got one of these Genelec 8010's to try out. I'm comparing it to a Tannoy 402 right now and the Tannoy seems to sound better in some ways. It only costs $100 too. I really expected the Genelec to be a step up since it costs 4x as much and is highly rated.
The Genelec has so little bass that it sounds really weak. I bought this one going on Amir's note that the speaker has a good amount of bass for a desktop setup... but it really doesn't.
The Genelec has so little bass that it sounds really weak. I bought this one going on Amir's note that the speaker has a good amount of bass for a desktop setup... but it really doesn't. And I don't even listen to really "bass-heavy" type music either... mostly just rock-ish stuff with bass guitar (Joni Mitchell Edith and the Kingpin playing atm).
I thought it would suit me well since I don't listen to bass-heavy electronic and hip hop type stuff, and I don't listen loud at my desk, but man it can't even get bass going for Joni Mitchell... seriously.
Maybe some measurements would reveal flaws of the Tannoy that I'm not aware of, but to me it just sounds better at least without a sub.
Here's a track I listened to for comparison. Even this kind of bass-guitar playing feels completely lost in the mix on the Genelec. On the Tannoy it sounds great to my ears.
Without a sub and for almost any type of music larger speakers will, by and large, just produce better and deeper bass. This doesn't mean every larger speaker is better just because it is larger, but that bass reproduction is very important and will trump a lot of smaller considerations. A larger speaker has a significant advantage with bass reproduction for reasons of pure physics.I got one of these Genelec 8010's to try out. I'm comparing it to a Tannoy 402 right now and the Tannoy seems to sound better in some ways. It only costs $100 too. I really expected the Genelec to be a step up since it costs 4x as much and is highly rated.
Maybe move monitors closer to wall?I got one of these Genelec 8010's to try out. I'm comparing it to a Tannoy 402 right now and the Tannoy seems to sound better in some ways. It only costs $100 too. I really expected the Genelec to be a step up since it costs 4x as much and is highly rated.
The amplifiers for the woofer and tweeter are just 25 watts. I suspect the amp is clipping before the woofer is:
I don't have the heart to show you the 96 dB SPL response.
There is an implicit assumption on this site that people will use subwoofers to fill in the low frequencies, as best practise, of course this isn't always the case in reality.
I have the companion Genelec Sub with the 8010s. Works great, but 8010 is obviously very nearfield.Bought a pair of these few days ago, and could not be more happier.
My only concern is, of course, the lack of bass. I listen to a lot of electronic music.
Some might say it would be better to get 8030...but those are much larger, and I'm not sure they are that better for a tiny desktop, than 8010 + a sub.
So my idea is to get a sub.
Is there a good reason to go with the 7040 from Genelec, apart from having a gene?
I mean, it's quite expensive, it apparently has a fixed crossover, and it's not particularly small (with a not particularly large driver).
Any subwoofer I should look at ?
Might want to check the manual and other docs, to get a better idea if it has what you want or not:Is there a good reason to go with the 7040 from Genelec, apart from having a gene?
@The French ideally you want a sub with crossover and XLR pass-through built in.
A sub from Genelec gives you this, but in return the sub cannot play particularly deep nor loud.
There's a thread discussing just this:
Subwoofer/DAC for Genelec 8020d or 8030c
set to the lowest gain that allows you to get the loudest volume you need. You have more sensitivity in volume control and likely lower noise (hiss) then. The lowest gains would be +12 and +6 right? I believe I read somewhere that the numbers were reversed / counterintuitive to what one would...www.audiosciencereview.com
~80Hz Xover works well for most mains, regardless of their stock frequency response.I'm a bit confused by that internal crossover thing.
I understand that the 7040 crossover is fixed (at around 85Hz).
But how can that specific crossover be right for different speakers ? I mean, the 8010s, 8020 or 8030s do not have the same bass abilities, right ?
Isn't it better to adjust that crossover manually, and to try to adjust with REW ?
That being said, if you can manually do the crossover, it's quite possible you can do it better.
