Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 5,237
- Likes
- 5,477
Probably lolI'm considering buy a single one of these as a nightstand/headboard speaker.
Have I lost my mind?
Just remember to sum to mono somewhere along the way. The benefit of Bluetooth speakers is that even decent single-speaker models do this summing on their own.I'm considering buying a single one of these as a nightstand/headboard speaker.
Wow! Gutsy. I'm very interested to see how the drivers withstand the elements (sun UV, rain, and snow if you have it there).Just wanted to show you my outdoor/balcony projekt using 8010's. Genelec does not reccomend outdoor use so i ripped the boards out and put them in a DIY box indoors. I DIY'd a ported subwoofer from sheets of fibre concrete using an SB 8" driver. Signal comes from spotify-chromecast-splitter-minidsp4x4. I choosed the 8010 due to good reviews, all ALU and plastic design, small size and good experience with my 8020's. The 8020s play nicely on their own in my 12'x12' kitchen but the 8010s definitely benefits from sub support except maybe in really tiny rooms. Spl is not a problem since i (sadly) can not play loud anyway.
Movies can have a high amount of dynamic range, which means that while the speaker may not be stressed out for 98% of the movie, they could clip for that 2%. The 8010A is only rated for 96 dB short-term max SPL at 1 meter and the further away from 3.3 feet you are from it, the lower that goes.I'm still considering the 8010 as a center speaker but I don't want to make the wrong decision.
I know people have suggested that it is not powerful enough for home theatre use but are they just talking about volume? Because my partner and I do not watch movies loudly.
I see, I understand now, we went for another 8030.Movies can have a high amount of dynamic range, which means that while the speaker may not be stressed out for 98% of the movie, they could clip for that 2%. The 8010A is only rated for 96 dB short-term max SPL at 1 meter and the further away from 3.3 feet you are from it, the lower that goes.
https://www.genelec.com/correct-monitors
Even the 8320As are only recommended for distances <= 1.75m. Not saying that the 8010As won't work for your purpose, but they are not designed for listening anywhere but near-field.
We sure have snow but i plan to keep them indoors in the winter. How they will hold up otherwise, time will tell. You win some, Lose some..Wow! Gutsy. I'm very interested to see how the drivers withstand the elements (sun UV, rain, and snow if you have it there).
Great review, thanks again! A note about using only small Genelecs in a desktop setup -> larger ones work as well In my opinion 8x3x series works the best also size wise. 8x4x begins to be too big for my taste at least. Here's my setup with 7350 sub on the floor.
These rather new Genelc desktop stands are the best imo begins one can adjust the tilt and they are VERY robust.
So, if you buy the Genelec sub (7040?) the bass problem with loudness goes away?Genelec's streak of 8+ w/sub Olive ratings continues.
I just wonders... the port seems not a good idea for using outdoor, as a lot of insects like those dark holes for hive. and insect bodies, nest building or excretions isn't any good to electronics, or say if you play one day finding some angered hornet coming out..We sure have snow but i plan to keep them indoors in the winter. How they will hold up otherwise, time will tell. You win some, Lose some..
That's the beauty of Genelec, though IME 7040A best to be used in a really tiny room with wall boosting, it can go to 25hz with that7040A subwoofer came in today. Haven't re-ran Sonarworks yet, but with current profile and sub added, it functions as a nice addition to the 8010A monitors. Everything seems very well balanced.
ic, then I am lucky, I have to use the -2db knob to not let bass overboosted, and my 25hz is basically in line with my 1khz level, although a 8db bass boost at 30hz resultsMy attic space is 10 feet wide with a 7.5 ft tall ceiling - thats why I chose this combo, for sure.
But because it's a tiny space, I'm fighting room modes that are something fierce, even with a lot of acoustic treatment. REW/Sonarworks show that the sub gets me down to 29 hz before it dive-bombs off to zero. By 25 hz, I'm already in a -12db null.
