lulHi Redacted,
Thank you for reaching out to us, I hope you are doing well.
Please don't worry, it is correct, compared with the single-section design, this type of double-section potentiometer is relatively loose, but its function is normal. You can use it with confidence.
Any thoughts and suggestions to optimize our product are welcome.
Please don't hesitate to reach out if you encounter any issues or have further questions.
Have a wonderful day, and thank you for your continued support!
lul
Edit: This is likely the last Chinese amp I'll ever buy![]()
Problem has been clearly explained and documented. Since you've mentioned the damage I'm not sure why you are asking.What's the problem with the product? Surely the damage was maded in the shipping company. Can happens with any brand / origin.
Hi Will I try it with the PS100? What were your impressions?I'm supposed to receive a SMSL PS100 which has HDMI ARC has an input, going to plug that suckers output to the V3 and see how well they play.
It's a shame to know that you had a bad experience. I bought one that goes on trips to use the arc hdmi so I can control the volume with the TV remote control, I hope I have better luck. When I install it I will tell you how it went.My unit of PS100 was faulty, it would put out lots of static noise coming in from HDMI ARC. I sent the unit back for a refund.
This brand told me that damage is "correct" and to use it with confidence.
Unfortunately I don't really know, what you told Fosi.I told them that I would like to return it, and they told me to put it in a vice and bend it back..![]()
