- Thread Starter
- #41
I'm learning that if you ask 10 audiophiles what makes a great amp, you get 10 different answers. I also love that the manufacturer is taking lots of notes and asking questions. Adding more features into a single box will just make the units too complicated in my opinion, which is why I think the stackable-component idea is so great.
On the EQ unit:
Someone mentioned parametric EQ. I love using parametric EQ on the Presonus StudioLive mixer, but I can't imagine putting that functionality inside a $100 box--good parametric EQ really requires a screen or LOTS of knobs. I think it's reasonable to ask for a compact multi-band EQ (using knobs) or maybe even a graphical EQ (using tiny vertical sliders) like the behringer FBQ. But real parametric EQ sounds too good to be true around $100.
For DAC, I think a multi-function DAC would be great, and a USB-only DAC really isn't necessary. The Apple USB-C to 3.5mm adaptor is already a high quality DAC for USB. And higher quality DACs are already available from places like Geshelli labs that include Optical + SPDIF + USB. Even then PCM is all you need for music. One could argue that a DAC could also include Wifi, Bluetooth and HDMI along with Dolby decoding, but then you're really competing with the large integrated AV amps.
Any device that has multi-input really needs to have a high quality input selector. A lot of these Bluetooth enabled amps have either NO selector or a hidden selector that's the "second press" of a different button. Personally, I would pay a lot more for a device that has a physical selector like the vintage Pioneer Amplifier selector switches. These knobs had a very good detent at every stop, so eventually you can memorize the knob and select your source in complete darkness.
On the EQ unit:
