tuga
The impulse response of Reflection-Free Zone studio:
@maverickronin, I've been trying to find research along the lines you suggested, and in fact it's amazingly difficult to find anything remotely similar.
I'm sure (although increasingly less so) there must be studies out there, but all I could find were either:
- studies concerning localisation of a mono source with presence/intensity of reflections as a variable
- studies concerning localisation of a phantom source under either reflective or anechoic conditions (but none in which the presence/intensity of reflections was a variable).
As you can see, while the degree of error is low for floor/ceiling reflections, the degree of error is gross for lateral reflections.
Angus further calculated that an absorption coefficient of only 0.5 would be required to bring the degree of error for floor/ceiling to a level below the degree of error measured for human listeners for a direct sound in an anechoic chamber (he says "only", but 0.5 is no mean feat at <100Hz!).
Meanwhile, an absorption coefficient of 0.99 (essentially removing the reflection entirely) would be required for lateral reflections.
That's very interesting, though I'm not exactly sure what that graph is supposed to be plotting. Is the Y axis the angle the phantom image is supposed to be offset by a given reflection? And then is each curve is the angle of the reflection?
The graph shows the angle of the ITD cue of the first lateral reflections plotted against frequency for a listener positioned between the two speakers.
The Y-axis is phantom image angle and the X-axis is frequency. Each line in the graph is the ITD cue of a given reflection for a phantom image of a given frequency.
For example, at 0° on both graphs (that is, when the phantom image is centred), both lateral and floor/ceiling ITD cues are completely correct (as you'd expect, because all path lengths are equal).
At 5° (that is, for phantom images panned 5° to either side), for floor/ceiling reflections, the ITD cues are close to correct (the bottom yellow trace, which varies from 4° to 6°)
But for lateral reflections of a phantom image panned 5° off centre, the variation in the ITD cues of the reflections varies from -7° at about 260Hz to 90° at about 100Hz, 160Hz, etc...
In other words, for floor/ceiling reflections, the relatively straight lines on the graph indicate that the ITD cues contained in the reflections are quite similar to the ITD cues contained in the direct sound at all frequencies/off-axis angles.
For lateral reflections on the other hand, the ITD cues vary wildly with frequency, and do not track the ITD cue contained in the direct sound.
That graph for lateral reflections is so ridiculously extreme though. It seems like the ITD error must be significantly mitigated by other psychoacoustic factors or else speakers in any normal room wouldn't image at all.
Choisel investigated the effect of loudspeaker directivity on the perceived direction of sound sources within a stereo image. Listeners were asked to use a laser-pointer in order to locate sound sources as they were panned between a pair of loudspeakers. Loudspeakers of varying directivity characteristics were used (B&W 801 and Beolab 5 with absorbing panels, Beolab 5 with reflecting panels), however results indicated that perceived direction was not affected by the alteration of this condition in this case [7].
[Choisel's] study examined stereo image localization using two very different loudspeakers, one (B&O Beolab 5) with unusually wide, uniform frontal dispersion, and the other (B&W 801N) with less than ideal forward-firing directivity (see Figure 5.11b for the similar 802N). The first side wall reflections were either perfectly reflected, or attenuated by “Rockfon absorbing tiles (120x60x5 cm).” Differences in loudspeaker directivity and the way they were aimed yielded reflection-angle sounds being 2 to 3.5 dB lower than the direct sound for the Beolab 5, and 5 to 14 dB lower for the B&W 801N. The test was to judge the influence of first lateral reflected sound on the precision of stereo image localization. Stereo images were positioned by interchannel amplitude or delay panning. Listeners indicated the perceived location with a laser pointer on the acoustically transparent screen that hid the loudspeakers. Stimuli were 1/3-octave bands of noise at 1, 2, 4 and 8 kHz, rhythmic hand-claps (anechoic) and female voice (anechoic). One would expect these signals to elicit well-defined images.
Differences were observed between amplitude- and delay-panned image locations, but “it can be concluded that the direction of panned sources was not affected by the loudspeaker condition (Nautilus 801, Beolab 5 with absorbers on the side walls, or Beolab 5 with reflectors) with the selected stimuli.” In other words, large differences in the magnitude of first laterally reflected sound arriving 9.5 ms after the direct sound was found not to have a significant effect on image localization across the stereo soundstage. Bear in mind that this was the only perceptual dimension being interrogated. Other spatial perceptions were not reported on. However, a significant fact is that the test room was about 24 ft (7.3 m) wide, with the loudspeakers placed 7 ft (2.15 m) from the side walls (and 9.8 ft (3 m) apart). The first reflection from the adjacent side wall arrived 9.5 ms after the direct sound and that from the opposite wall, about 23 ms (my scaling from a drawing that seems not to be exactly to scale). This is a large room, and earlier-arriving, louder reflections in a smaller venue would have provided more persuasive proof
@maverickronin I have finally stumbled upon a study investigating the effects of early lateral reflections on image localisation with a stereo pair of loudspeakers.
Unfortunately, I can't get my hands on the original study, so all I have are descriptions of it in other literature.
The authors of this paper describe it as follows:
Toole goes into more detail in his book:
Interesting. Seems like in a big enough room neither directivity nor first side wall reflections might matter all that much.
Exactly. Taking the findings of the study at face value, the next question would be to ask where the threshold lies, i.e. how much narrower does a room need to be before early lateral reflections begin affecting phantom image localisation?
One could arrive at that conclusion by resorting to good old common sense but it is nice to have a study which confirms my suspicions regarding large rooms or wide front walls.
Maybe one day someone will design a renderer that will calculate sound reflections.
I'm surprised that's your reaction. Earlier in the thread it was your position that any reflection earlier than 15ms must be absorbed or reflected away from the listening position to preserve proper imaging, if I'm not mistaken?
I have defended from the beginning that narrow rooms need treatment early reflection zones in side walls or that dispersion need to be narrow.
Unless I'm mistaken, when the room is very large and/or the front wall is very wide early reflections coming from the side walls will be delayed and lower in level.
But what about early reflections before 15 ms? These reflections can cause image shifting and ruin your sound stage. Here’s where we need acoustic treatment to create your RFZ
Perhaps Toole's study should have been performed in a narrow room.
Conspiracy theory: a study was performed but the results didn't please, thus study was not published?
However, a significant fact is that the test room was about 24 ft (7.3 m) wide, with the loudspeakers placed 7 ft (2.15 m) from the side walls (and 9.8 ft (3 m) apart). The first reflection from the adjacent side wall arrived 9.5 ms after the direct sound and that from the opposite wall, about 23 ms (my scaling from a drawing that seems not to be exactly to scale). This is a large room, and earlier-arriving, louder reflections in a smaller venue would have provided more persuasive proof.
In post #859 you said:
That seems to conflict with your more recent statement it is a matter of "common sense" that early reflections of 9ms delay should not interfere with imaging.
Toole never studied this AFAIK. We're talking about a 2005 study by Choisel
About this Choisel study, Toole says:
Tax me, I got the numbers wrong.
The idea comes from control room design, LEDE (live end dead end), RFZ (reflection free zone), non-environment room, Controlled Image Design etc etc. In a control room the engineer needs to hear the early reflections in the studio and recording, so they need to suppress the early reflections in the smaller listening space (control room). It was about being able to accurately hear what was being recorded, nothing about stereo image in the control room, and no explicit specification of 15ms as it depended on the early reflections in the recording.The idea that all early reflections below 15ms are extremely bad for the stereo image and inevitably lead to sound coloration is often found in forums.
Sometimes it is also demanded to suppress the reflections up to 15ms completely.
I think that a specification that is intended for studio recordings was transferred to the hifi world. For studio recordings the requirement is to avoid early reflections up to 15ms, because otherwise the recordings are "blurred" (without an increase in spatiality).
This is somehow plausible, since early reflections always occur when listening in living rooms, it is certainly not an advantage if the music signal contains additional early reflections.
A very important aspect of early reflections in living rooms is their masking. The negative effects of early reflections like comb filter effects or roughness and beating are masked by other reflections.
This means that a reduction of the reverberation time, for example, can lead to a stronger perception of the negative effects of early reflections.
Also very negative are single very early (little attenuated) reflections, such as those caused by a mixing console in the studio or by the living room table at home.
The whole context is much too complex for a simple rule like "avoid early reflections up to 15ms" or "...never feed it after midnight".
