Eversolo DMP-A8 Balanced Streamer/DAC Review
Rate this streamer/DAC/Preamp:
    Votes: 8 1.7%
    Votes: 12 2.6%
    Votes: 89 19.1%
    Votes: 357 76.6%
For people worrying about longevity of supported app, avoid using them! This is why I advocate for "push streaming" such as how Roon works. The streamer then becomes a simple endpoint. As long as that protocol remains the same, the device will not be obsoleted. In contrast, using the local app relies on that app being around ("pull streaming"). This is why I waited to review the DMP-A8 until it had Roon support.
I have changed my mind about it due to it being "pull steaming" (even though I am not very likely to stream at all, I may change my mind further down the road).
It just seemed that it had the potential to be a one box solution, no computer needed in the system.
You can pretty operate the entire thing via the front panel touchscreen, can't you? Plugged into a network/wifi and an onboard SSD would make it pretty much a one-box solution (plus power amp obviously) wouldn't it?
FWIW , I have a Yamaha wxc-50 in use in a bedroom system- Yamaha hasn’t updated the firmware in YEARS - and they’re still being manufactured and sold by Yamaha today…
End result , it functions fine but won’t do Tidal hi-rez FLAC - and probably never will - unless they do a FW update - which I doubt.
Bk
Looks really awesome. I’d like to see it with a crossover. Most people have a sub, and many have a mid-bass - that would be a grownup (mid-high-end) preamp.
It would for stored content. But for streaming, you need a different solution.
Wish It had an on par headphone amplifier included...
I assume using the RCA or balanced outputs will not do :-(
Yes, pretty much all. In my case, I can activate Qobuz streaming just by touching one "Q" button on the home screen. Easy. I can then go through my Qobuz playlists and control each playlist/song from the touch screen. Again, easy. Same for internet radio, push one button on the home screen and there you are (have it defaulting to TLIS in Slovakia). Takes a few more touches to reach Arc input for TV, or other inputs for CD or what have you, but again all pretty simple from the front panel touchscreen. I haven't yet loaded music onto the SSD, but A8 formatted it from the front panel touch screen just fine (not sure what others use, but I installed a Crucial P3 Plus 4TB PCIe Gen4 3D NAND NVMe M.2; note that is a gen 4 and the A8 only supports up to gen 3, but confirmed with Eversolo that gen 4 still works fine and indeed it seems to). While the plasticky remote control is a bit non-intuitive and takes some gleaning from the manual to figure out, the front panel touch screen is much more intuitive and does all I need (so far) including full control of streaming. Easy peasy.
@amirm will you be testing the new Zidoo UHD8000, Eversolos sister company when it is released? Assuming either they or some other members sends it in to you.
Voted “not terrible”
SOTA gear that is overpriced from legacy luxury brands is not terrible but many would prefer SOTA gear from many of these new upstarts.
In 2024, it’s pretty incredible that WiiM has beaten Topping, Eversolo, SMSL, etc. through the power of DSP. None of these stuff will beat a WiiM product with PEQ. If you don’t need PEQ, it will sound similar in blind testing. If you can benefit from PEQ, the WiiM will win.
Are you sure you’ve posted in the right thread ? This is Eversolo , one of those Upstarts as you say, certainly not a legacy luxury brand
But still that means the A8 has to remain compatible with the Roon App? I'm assuming the Roon App is actually stored & launched on the A8? So isn't it likely that over the years it's possible that the Roon App will no longer be compatible with this old hardware? I might have the wrong end of the stick, if so can you explain the connection diagram setup?
(If you mean by "push streaming" that you have Roon on a seperate PC for instance that you have hooked up to the A8, then I don't understand how the A8 remains useful in that situation because the idea of the A8 is to get rid of the PC as I see it.)
I like the idea of this if I was to to go with Roon instead of Squeezebox. Then again if I'm using Roon, do I need PEQ in the player itself? Really though I would want it to support Squeezebox and have a larger touch screen before I would buy it. 6" is maybe OK for my fingers and eyes but in the pictures the screen looks a little small.
Having both a PC with Roon as well as this all in one streamer and server would seem a bit pointless. Either one or the other for simplicity. For this money I would want it to do everything and not use a PC or NAS with it. It would also have to be able to stream to and sync with all my other streamers in the house. Definitely needs a bigger screen in that case although maybe I would be looking to control this and all my streamers from my chromebook instead. Tablets don't really cut it due to the lack of built in keyboards and phone screens are too small (for me).
Yeah. Completely talked myself out of wanting one of these now.
You don’t have to use a PC or NAS with it, you can simply add internal storage 4TB to the A-8, Wiim doesn’t ‘beat’ as streamers they sound identical, just ta question of features.
I use mine with Roon which is undoubtedly the best playback software I have used.
Doesn't that depend on the OS/app running in that "simple endpoint" remaining Roon-compatible? (Crazy price of Roon is another matter.)
If you install a large SSD and put all your music on that, it becomes a player, not a streamer, like a CD player with a near-infinite stack of CDs, doesn't it? Of course, you still have the "remote" streamer functions if you want them.
Around half of participants either chose the dongle or couldn’t tell a difference.
This needs to be stressed, regardless of any quibbles of how Archimago ran the test. We are talking about Apple's $10 adapter vs $3k Linn streamer vs $20k Linn streamer, and don't forget that only keen listeners are likely to take part in the first place.
