Eversolo DMP-A6 Streamer Review
Rate this streamer/DAC:
    Votes: 7 1.2%
    Votes: 30 4.9%
    Votes: 159 26.2%
    Votes: 412 67.8%
Salut tout le monde, je commence à utiliser "Squeezelite" mais je ne peux pas accéder au SSD de l'Eversolo... Dans quel dossier regarder sur LMS ? merci à ceux qui me guideront :)
This is originally a very simple function, but supporting third-party apps complicates things. Some applications will seize the Audio track channel after launching. Anyway you can try turning on this switch: Home - Music - Play - Auto play at boot
Where in the menu can I find this set of commands?
where can you download the 1.2.37 firmware? when i ask beta versions via DMP-A6 mater edition it just says my software is up to date.
cheers!
Further up this thread I believe if you look for @mirror88 postings.
1.2.37 is installed automatically after you manually install 1.2.36.
Many thanks from me for Parametric EQ, great job!!!
Z6/Z8 will get the new VUs soon but have no EQ support. Sorry but the product attributes of DAC determine that its update frequency will not be too fast
Thank you so much @mirror88 , Z6/Z8 users have been feeling neglected for a while so this should make them feel their purchase worthwhile.
Any chance for spectrum analysers? Volume passthrough?
Also at least fixes on the bugs, spelling, and I also hear about remote issues.
I may face some bugs for EQ and eversolo app
While listening, so from the page with picture album, acessing EQ will bring me to a black page, and the EQ doesn't work any more
I also access EQ from the main page, here i can go in EQ and chanhe bands, but what ever i change doesn't act on sound. I was on a flac 44.1
I did tried everything, but EQ doesn't function anymore
I will try a factory reset and reinstall alpha version to see
Personne n'a de réponse à m'apporter ? Serrez connectée et SSD
@Cepi si tu ne parles pas anglais (ce que je peux comprendre...) utilise Google translate, tu auras plus de réponses. Quant à moi je n'utilise pas Squeezelite.
Reactions: CMB
Hi, when the SSD formatted in exFAT is not visible in DMP-A6, then is only way to format it in NTFS externally or is it another way how to make it alive? Thanks. Cheers.
Hello, Can you use the PEQ and the A6 as a Roon endpoint or this input can't work with the PEQ features ?
For PCM the limit is 192Khz, but for DSD I suppose it is DSD64 ?
I haven’t tried PEQ with the A-6 but with the A-8 ( which I imagine is the same) you can add peq to all these inputs, I use mine with Roon connecting via USB.
Do not seem to have a "Network input" in the list ... So for the Roon ready part it seems to not be able to work ? Only with internal player or physical input ? Or am I wrong ?
Typically I have cut off ‘internal player’ which is top of the list!
I have tried this Alpha update on my Eversolo master edition with PSU upgrade via XLR out, and found the EQ 15 band way to fierce in adjustment. creating terrible distortion. It takes the adjustment way to far in many aspects. EQ gain at -6 is better for control than -5 the Parametric EQ is better but still causes distortion. The filters offer very little really and they need to offer some pre sets in EQ ie: Voice, instrumental, Bass, ect ect. I have been messing around for hours with both kinds of EQ and have to say the Wiim pro 2 EQ is so much better.
A great idea from Eversolo but needs work before final release for sure.
PSU ‘upgrade’, surely the PEQ is only as fierce as you make it, EQ doesn’t usually lead to distortion, I would only use EQ for ameliorating room derived bass peaks.
I never go more or less than 5dB on PEQ, otherwise the speakers must be replaced with much better ones.
Lower the general volume level by 5dB, on XLR there are 4V RMS.
I have been trying more settings and have found a good setting. -6 on gain setting for a start. PEQ
31.5 = +5db
63 = +4.8db
125 = +4.1db
250 = +1db
500 = +2.2db
1kh = + 1.7db
2kh = +3.6db
4kh = +4.1db
8kh = +3.6db
16k = + 2.2db
These settings offer the best sound so far, I might well change a few but have so far found this to sound the best. these settings are XLR from Eversolo master edition in to a Boxem 4215 amp via triangle BR08 speakers. for everyone else it would depend on your speakers but try these settings and see what you think you might have to adjust to your speakers of course.
