ES9082 SABRE DAC with integrated DSP
Matias
São Paulo, Brazil
Not only a good performance DAC but now with integrated DSP. Hopefully the manufacturers of "DAC of the month" can now start adopting its PEQ and DRC going forward.
Incorporating the latest generation of SABRE high performance DACs with integrated Line Driver
Sept 23, 2024 – San Jose, California – ESS Technology, Inc., the industry leader in audio semiconductor devices, today announces two 8-channel DACs with integrated line drivers with exceptional performance. The incorporated ESS patented Hyperstream® IV architecture provides the listener with the legendary SABRE® sound quality with improved audio performance and a refined and enjoyable listening experience.
The ES9082 SMART DAC and ES9081 DAC are ESS’ next generation devices that deliver a True DNR of +120dB and -108dB THD+N with 2VRMS line driver for each of the 8 channels allowing for an amazing audio experience while reducing the Bill-Of-Material (BOM). Channels can be summed to improve performance in an application requiring fewer channels. A 2-channel differential configuration can achieve up to +127dB DNR with a 4VRMS output. ESS’ True DNR performance does not rely on Dynamic Range Enhancement (DRE) technology that shows higher DNR but is known to cause pop noise in some applications.
The ES9082 SMART DAC incorporates a 2nd generation of ESS Audio Signal Processor (ASP2) that allows customers to integrate their preferred audio algorithms by using ESS’ proprietary SABRE Intelligence Studio graphical software tool. For example, customers can integrate multi-band PEQs, DRC, AGL, MIXERs, Audio Expansion and Compression, stereo widening, and specialty filters such as RIAA de-emphasis and cross-over filters. Incorporating these algorithms in the SMART DAC improves the audio performance and simplifies the audio system. In addition, a 2-channel input is available to mix a secondary stereo source such as a microphone monitor into ASP2. The ASP2 can be programmed using the slave I2C, slave SPI interfaces or the SPI master interface with an optional external SPI Flash memory for very fast program loading and for storing multiple configuration programs.
The serial data interface supports TDM, TDM Daisy Chain, I2S, LJ, DoP and DSD input formats with sample rates of up to 768kHz (using 64FS mode) and DSD1024. The integrated TDM & S/PDIF output encoders allow for a variety of systems design considerations.
Other features:
SPI and Hardware (HW) modes for more versatility in configurations
The integrated proprietary Analog PLL eliminates an external oscillator with no effect on performance.
Digital Volume range from +1dB to -126dB in 0.5dB steps with 0 to +42dB pre-gain in +6dB Steps
8 internal digital filters
Very low noise DAC reference regulators
8 input channels of PDM are supported
The ES9081 without ASP2 capability is drop-in compatible with the previous generation of ES9080 and allows customers to upgrade seamlessly and achieve higher performance with their current systems.
The ES9081 & ES9082 SABRE DACs are ideal companions for Professional Audio equipment and mixers, Soundbars and Powered Speakers, A/V receivers and integrated Amplifiers as well as Class-D pre-amplifier controllers.
The ES9081 is available in a 40 pin 5mm x 5mm QFN package.
The ES9082 is available in a 48 pin 7mm x 7mm QFN package.
Reference boards and designs, SABRE Intelligence Studio (SIS) software, and samples are available. For more information, please contact your local ESS Technology representative or distributor.
More Information about ESS Technology and their products can be found at http://www.esstech.com.
About ESS Technology
ESS Technology, since inception, has been on the cutting edge of audio technology. A privately held fabless semiconductor company, ESS Technology designs and markets high-performance analog and HiFi audio devices for the consumer, professional, and automotive audio sectors. Celebrating their 40th Anniversary in 2024, today ESS Technology is best known for its SABRE series of world class audio products. For more information, visit http://www.esstech.com.
This is already being done with some creative firmware by @fabriceo for the Okto DACs. Good days to be into DSP and access to great tools!
See Okto release here for extensive notes on how to use such DSP, hopefully there'll be a decent GUI in the near future:
@Matias , my understanding is that only the ES9082 has the DSP feature, you may whish to revise the title of the thread.
@boXem nice catch, thanks.
If I understand correctly on the Okto you need to reflash to get a different EQ.
It's not "reflashing" necessarily but it's not an easy process with a GUI either. It is more powerful than other on-chip methods though.
When I see a device with such features, I am always a bit suspicious that the DSP would be put in use by a manufacturer, unbeknownst to the end user, in order to create a "house sound" without necessarily give the end user access to some equalization features.
I once read in the user manual of Texas Instrument's PA software environment for DSP for Dolby decoding that access are given to designers to implement processing not acknowledged by Dolby and that such manipulations should always be check by ears to assess their effects on the sound. Since that reading, I am always afraid that complex systems have undocumented features that might be used to alter the sound of a particular device instead of kip it straight and transparent.
NTTY's test of the Denon "Alpha processing" embarked in the DCD-SA1 and DCD-900NE has demonstrated that that manufacturer have created devices that auto-detect test signals and in that case bypass the usual digital signal processing apply on music in order to shine with measurements. Hence, my concern is not entirely baseless, I think.
DSPs are used for decades for exactly this purpose in active speakers of all sorts.
I would like to see chips from them that will natively support the higher voltage requirements of MEMs drivers. That being said does ESS even make DACs or CODECs that support a Microphone ADC anymore?
I have noticed that the ES9082 and ES9081 are already available. Regarding the DSP part:
No surprises, proprietary software tool.... anyways, maybe a step forward from the cheap as chips walkplay enabled dongles. The direction seems the good one IMO.
That's the same stuff as the one embedded in their ADCs.
Yes, I was wondering why they would add RIAA EQ to a DAC
