- Joined
- Sep 16, 2019
- Messages
- 1,199
- Likes
- 2,646
- Thread Starter
- #201
Hi,
Let's start with the F206 only. No EQ: 6.27
It is not easiest to EQ but we'll see how it pans out.
The score are probably not that accurate because they are not from the raw data.
Take them as relative scores rather.
again, can you discriminate between them and the raw speaker?
If so is there one better than the others?
I did not see, maybe I missed it, any clear answer for the M105, could you give us your final conclusion at one point?
Code:% H1: 7.03 x0=[ 221.0, -0.66, 6.43,... 375.0, 0.95, 2.53,... 598.0, 0.48, 6.50,... 1100.0, -0.33, 0.50,... 1324.0, 1.65, 3.82,... 2145.0, 0.73, 5.30,... 3435.0, 1.13, 3.00,... 5340.0, 0.75, 8.40,... 10010.0, -0.50, 11.1,... 11560.0, -0.75, 3.80,... 4333.0, -0.00, 3.60,... 1]; % SL: 6.94 x0=[ 223.0, -0.46, 9.00,... 375.0, 1.40, 2.53,... 570.0, 0.51, 6.50,... 987.0, -0.43, 0.61,... 1321.0, 2.00, 4.00,... 1820.0, -1.24, 3.70,... 3435.0, 1.65, 3.00,... 5350.0, 0.75, 12.5,... 9924.0, -0.67, 7.60,... 11560.0, -1.10, 2.60,... 4333.0, -0.00, 3.60,... 1]; % SC 7.14 x0=[ 223.0, -0.46, 11.1,... 375.0, 1.40, 2.53,... 570.0, 0.66, 4.70,... 987.0, -0.33, 0.69,... 1331.0, 2.00, 3.22,... 1721.0, -0.88, 5.45,... 3435.0, 0.90, 6.00,... 5351.0, 0.69, 14.3,... 9924.0, -0.61, 8.60,... 11560.0, -0.95, 2.00,... 4333.0, -0.00, 3.60,... 1];
So, this took longer than expected. I can't say the differences were dramatic with any of them compared to the original. I decided first to find out which filter I liked best on a variety of material, and then compare those to the original and my own. After testing blind over the course of two days, I settled on filter what turned out to be filter #2. I found it overall less fatiguing than the other two.
Today I performed a new blind test compared to the original and my own filterset, today - I really had to split this over some days as it does become tiring and my results seem to become less reliable as time passes.
I ended up preferring my own filter as the best, followed by your #2 filter, followed by the uncorrected speaker. I found my filter sounded the smoothest and most balanced on most of the material. The big difference I found was overall balance, with yours sounding a bit brighter/clearer.
Now, I haven't loaded yours into REW yet, so I'll let you do the honors and if you care to calculate the score to my filters.. I'd be curious to know - here are my filters:
