- Joined
- Sep 16, 2019
- Messages
- 1,402
- Likes
- 3,322
Hi Guys (& gals?)
Since there's been some discussion about how the different anechoic curves affect listener preference I'm going to attempt to gather some people here who own loudspeakers that have been tested here on ASR. The goal of the test is simple. We're going to experiment with different filter settings based on Amir's anechoic measurements and see what we come up with.
Some context: There have been many speculations about what is most important to us as listeners. Some claim the listening window needs to be as flat as possible, others want the estimated in-room response to be as smooth as possible, etc.
I'm in luck as to owning three (well designed) models that have also been tested by Amir, and have been experimenting quite a bit over the last few weeks if there is indeed something that can be universally applied to improve most if not all loudspeakers **please note I'm fully aware there are many things EQ can not fix**
I'm now looking for volunteers who also own speakers tested by Amir, to casually try some filter settings. If you can do it blind, all the better, but any input is appreciated.
Prerequisites:
A good start would be that your system is already calibrated in the low range. Please note that any filter settings based on anechoic measurements that are in your own standard 'EQ range' will be superimposed on said filters and will likely further affect perception. They should be turned off or adjusted so that the low range remains constant. If you can share some details about the position of your speakers relative to the walls this would also be appreciated.
TBC
Prerequisites:
TBC
