Well, if you're saying that PIRDI
alone is a poor choice for a scoring system, then I 100% agree with that. If I could only use
one curve for scoring speakers, it would be ON/LW, consistent with the
@Floyd Toole philosophy "if the direct sound is wrong, nothing else matters". But in practice we don't have to constrain ourselves to a single curve, so I would use both ON/LW and PIRDI.
Here's why I disagree with the conclusions you draw from your example: the directivity of the speaker you're describing
is perfect. And my proposed scoring system that uses ON/LW and PIRDI
will penalize the speaker, because it has a peak in ON/LW. It won't penalize it because its directivity is wrong (it's not), or because its PIR is wrong (I say we don't hear that directly), it will penalize it because its direct sound is wrong. In other words, it will penalize it for the right reasons (causality), at least according to my hypothesis.
Imagine the opposite situation. Let's say I have a similar speaker with the same peak in ON/LW, but its PIR doesn't have that peak (i.e. PIR is perfect). Is my speaker better than yours? According to your philosophy, it is, because PIR is better. According to my philosophy, my speaker is actually worse because it has a directivity error that your speaker doesn't have.
