This argument has been made a few times on various threads =]. I personally do not agree that a high-pass listening test should be the priority, if implemented at all. Mind you, I agree
in principle about how people should optimize bass performance in their own systems, but I do not think it is a reasonable or fair approach to evaluating and recommending speakers.
Most people do not listen with a good subwoofer. Well, maybe most ASR members do, but not the average audio enthusiast. If they have more than one speaker system, they might use one for their main system but not their secondary one. So my perspective is a bit different: Most audio reviews pay little attention to bass in favor of things like "resolution" or "transparency," so it's refreshing to see bass be given the priority it deserves. If we ignore bass extension, then it seems there's little reason to appreciate speakers that do reach lower.
I also disagree with "any speaker's bass can, and should, be remedied with a subwoofer." Certainly most passive would benefit from it, but every year there are more active designs that can reach deep into the 20s, with enough headroom for many typical listening situations. The tiny
Devialet Phantom Reactor, let alone the bigger ones. The
B&W Formation Duo as well, and seemingly Buchardt's
upcoming A500. For both the Reactor and Formation Duo, I simply was not able to get crossing the speakers with a sub to sound better than a pair of speakers playing full range - despite both of these being compact bookshelf designs (especially the Reactor). I rarely if ever listen above 75 dB at my listening position 10 feet away and in my home both pairs still have a good 20 dB or so of headroom before compression starts to kick in.
Then there's the problem of assuming someone already
should have a subwoofer. If not, a decent subwoofer will set you back at least $500, probably more if you want to go all the way to 20Hz or below. But then you should probably have two to deal with room issues, so now you're set back twice the money. Some people don't have space for a sub - this was the case for much of my audiophile journey - let alone two. And then properly implementing crossovers can be a pain, which is why many people end up giving up on subs. In the majority of cases, decisions on aesthetics, practicality, and financial investment are limiting factors.
Then there's the fact that implementing a high-pass filter will alter the balance of frequencies. Consider the two speakers being discussed - the Emotiva reaches lower, but the 305P has better balanced low mids. I would assume that implementing a filter would unfairly benefit the 305P as the Emotiva would sound comparatively anemic without the extension to "fill out" the timbre. It would also depend on what frequency you choose.
So I say look at the data and decide for yourself what's best if you plan on using a subwoofer. I appreciated the insight in this case about how the bass extension made a difference in preference.
That said
@MZKM's implementation of Sean Olive's preference score also includes a metric that ignores low frequency extension. I think that number is probably more useful than a quick informal listening test without an optimized subwoofer implementation.
