Never meant to imply anything about budget, or home size, or anything of that matter. Stating dual subs are necessary for high fidelity is not a subjective opinion, or any kind of judgment about peoples choices, but rather just an objective statement. L/R speakers placed for imaging will have very poor bass response below 300 Hz and eq cannot fix large nulls or dips in the response. Poor frequency response is not high fidelity. Most of the time, I don't think people *can't afford* or are *unable to place* dual subs. Most often, imo, they choose not to in the pursuit of "pure" sound by using 2 channel with no eq. So it is a bit ironic that, in the quest for the best sound, we purposefully choose lower fidelity by foregoing subs.
As an example, I see many many examples of folks with $2,000/pair+++ speakers running 2.0 without subs. This is a choice that is not about what one can afford. There are plenty of affordable solutions for decent little subs such as the JBL 550p that often goes on sale for $189. It is true, I don't think it makes sense to spend thousands on speakers and gear, obviously in the quest for great sound quality, only to limit fidelity by choosing to run without sub or subs. Obviously, people can set up their systems however they choose, but 2 speakers without subs is not the objectively high fidelity system. So doing so if the goal is sound quality doesn't make sense.
It goes without saying that if someone has a tiny space, apartment or are completely controlled by a spouse, a sub might not be an option. I wouldn't use one if I was in an apartment.
As far as having ideal response at one specific location, that simply comes down to user preference. I could have a "perfect" response at the MLP if I chose to sit completely still in one spot at all times, but I chose to have a very good response at all seats, can sit wherever I choose, move around if I want, and not have a poor response. It sounds great everywhere. But you are absolutely correct that a perfect average response results in a less than perfect response at most positions. But I choose very good everywhere.
Cool, we're mostly in agreement! Sorry if I came off argumentative. I definitely am all in the "get a sub" camp for people who refuse to get a sub for the sake of "purity," not for lack of space or other reasons.
In my case, somewhat limited subwoofer positioning options means sometimes full-range sounds a bit better - with the Phantoms I wasn't ever really able to get my subs to sound better than just letting the Phantoms play full range. I'm sure I would've been able to with some more messing around with positioning and EQ but I wasn't sure it was worth the hassle.
And yeah, it's all about the primary LP for me. The way my furniture is set up I pretty much never have to sit elsewhere, and my girlfriend isn't someone who notices these things.
You don't really need to spend a lot of money on subs, less than the difference between bookshelf speakers and the tower version most of the time. In my extreme case I bought some cheap Polk PSW 505 subs a few years ago for 200 each and have EQ'd them flat from 20-100Hz in my room. So for about $1400 for 2 Bookshelf speakers and 2 Subs, I have good response from 20-20k, no tower is going to come close to that. I don't have much room for subs myself but I made it work by placing short stands on my subs and putting my speakers on top, you lose some of the placement benefits of the subs but it's still better than towers without subs.
For the record, I'm not saying a 2 Channel setup without subs is going to sound terrible or anything but it's just not possible to match a proper multi-sub setup if you're going for the smoothest response.
Sure, that's an option, and again, I always agree bookshelf + sub >>tower. If it can't do a clean 30Hz, it can't play a lot of the music I like well. I just wish more sub companies took a little care in aesthetics... Luckily I don't need too much in the way of SPL so small subs I can tuck away do the trick for me.
