- Joined
- Feb 5, 2019
- Messages
- 3,688
- Likes
- 4,070
Or a -12dB preamp.If you want to tell whether APO is working then try a filter that will be massively obvious like 400Hz high pass.
One reason APO wouldn't work is if you use WASAPI or ASIO.
Ahh, interesting. I didn't get around to reinstalling it last night. I will look out for this when I reinstall and see what happens. Thanks.If you are running Windows 10, chances are you have to go into the "Troubleshooting Options" that EqualizerAPO's Configurator offers and select "Install as SFX/EFX (exprimental)" for the output device. The default of LFX/GFX will not work.
Yes, exactly right in both cases.Maiky stated that "the vertical directivity is rather poor because of the high Xover point" and also "best to listen off axis at +15/20deg." Here's the graph posted with these suggestions below.
Does this mean that vertically, the speakers should be in line with/pointed at your ears, but then horizontally they should be angled out a bit so they're not directed right at you?
Don't buy these crappy speakers, if you want to listen to music. It's just money down the drain. Better buy iloud Micro Monitors, Fluid Audio F4, Mackie CR4.. or something like thisI've been eyeing these speakers given their low price and wondering if they would be an improvement in sound quality after EQ compared to Logitech Z906, Z5500 or Z5400 for music listening. Anyone having both and able to share their opinions ?
Lol, you mean don't buy the crappy recommended speakers ? Checking the 3 you mentionned, the CR4X are available and same price as these Edifier. In what way are these Edifiers that bad compared to the CR4 ? Just read an Amazon review comparing both and they seem to be on par.Don't buy these crappy speakers, if you want to listen to music. It's just money down the drain. Better buy iloud Micro Monitors, Fluid Audio F4, Mackie CR4.. or something like this
Who recommends Edifier R1280T ? Amirm? He decided it was ok for 100 bucks.Lol, you mean don't buy the crappy recommended speakers ?
No need to be sarcastic I want recommended speakers with or without PEQ but the "recommended by Amir" label won't convince me if they sound bad. I'll wait for few days to get other potential reactions then order the CR4 and Tannoy402.Who recommends Edifier R1280T ? Amirm? He decided it was ok for 100 bucks.
But I wouldn't listen to it even if I got paid for it.
Mackie, Fluid, iLoud... pretty much anything would be better than R1280.. Or Tannoy 402 for example.
But personally, I wish you to choose exactly the recommended R1280T.
"Recommended" - this will be your main thought while listening to music
«how to get the best/same sound out of all»… - sell these, buy Iloud micro monitors - it has flat frequency response by default and has bluetoothI have a pair of these speakers on the way with the following inputs planned: PC, chromecast audio (for google integration), PC #2. I'm trying to understand how to get the best/same sound out of all.
Based on what I've read in this thread the use of EQ is pretty important to make these speakers sound their best. For the main PC I have full rights and can EQ based on the settings described previously. The chromecast has rudimentary treble/bass settings but that's it. On PC #2 I cannot install software EQ.
If I don't want the latter inputs above to sound like crap am I stuck with using the bass/treble knobs on the speakers to make all sound "ok", but none sound "good" (via true EQ settings)? Is there any inexpensive upstream box I can insert that supports custom EQ that I could run all my inputs into, EQ there, then run its output to the speakers? I've been looking at small DACs and don't see any that allow settable EQ at custom frequencies.
These will be pure desktop speakers in my home office. I'm sitting 2-3' away and don't need a ton of volume, though at times I do pull back to 6' or so for gaming. The alternative I've also looked at is an amp (e.g. A7 or AD18) and passive speakers but that doesn't solve the custom EQ issue as far as I can tell, and part of the draw to active speakers is minimizing desk space (no amp/DAC/etc).
I'm a bit lost here so appreciate any advice!
I have looked at them but they do not meet my needs for connectivity.«how to get the best/same sound out of all»… - sell these, buy Iloud micro monitors - it has flat frequency response by default and has bluetooth
