DVDdoug
- Joined
- May 27, 2021
- Messages
- 5,672
- Likes
- 8,211
My biggest issue is - If burn-in is needed, why doesn't the manufacture burn-in at the factory?
And the manufacturer should verify the specs before the item is shipped, not assume it's going to be in-spec after some burn-in time. Although I assume most speaker manufacturer's don't thoroughly test every single speaker.
I've worked in electronics (non-audio) for a few decades. Most of the companies I've worked for burn-in their products before shipping (usually between one day and one week at elevated temperature). Where I currently work it's 2-days. The burn-in is NOT to improve the specs/performance, it's to weed-out early failures.
The units are tested before and after burn-in. That doubles the testing-cost but the actual burn-in essentially costs nothing, other than a delay. And in fact, more units/boards fail before burn-in (manufacturing defects or component defects) than after. Post burn-in failures are rare and most are actually manufacturing defects (an intermittent solder joint, etc.) rather than a component failing or aging & drifting out of spec.
I realize that a speaker is different from a purely-electronic device/product, but if electronics can be burned-in at the factory, speakers can also be burned-in at the factory.
