Does this now mean that we can move on from Dirac 3.4.4 to 3.11 now for Arcam receivers?I just tried the new beta and I did not have any imprecise measurement errors
I did a 9-point measurement and everything went smoothly, no issues or any kind of error messages whatsoever
I am happy to report that it seems that Dirac finally got fixed - although it would be great to hear from others sharing their experience too
One question, is it worth buying a UMIK2 as opposed to a UMIK1, I mean purely from a sound perspective, is the result better?They were perfect for all channels
Note that I use UMIK-2 that has its own clock source (unlike UMIK-1) and hence it can measure acoustic delay in a much more precise and consistent fashion
No; purely from a sound perspective you should not switch. But if you do acoustic timing reference measurements then you shall definitely switch - or if you see that the delay values Dirac measures are not realistic or highly inconsistentOne question, is it worth buying a UMIK2 as opposed to a UMIK1, I mean purely from a sound perspective, is the result better?
This is exactly where Dirac Live needs precise data for proper processing. And currently this still seems to depend very much on the clock reference, which can vary depending on the hardware available. You should also bear in mind the masking effects of the UMIK-1, i.e. you should calibrate with at least 85dB.acoustic timing reference measurements
so this update hasn’t cured the problem? I just can’t bring myself to test another Dirac update unless chance of success is atleast 75%This is exactly where Dirac Live needs precise data for proper processing. And currently this still seems to depend very much on the clock reference, which can vary depending on the hardware available. You should also bear in mind the masking effects of the UMIK-1, i.e. you should calibrate with at least 85dB.
I’ve seen this a few times but unsure what it means. The Dirac app doesn’t seem to give a dB reading when you are setting volume (maybe it does and I’ve missed it!)With a UMIK-1 you should calibrate with 85dB if possible.
If you are not using the UMIK-1, this may also be sufficient. With the UMIK-2 this is possible without masking effects, as the self-noise is lower here. I will measure our NAD mic more precisely when I get the chanceIt doesn't work for me at such a high level, Dirac then says invalid measurement or something, I don't know exactly. For me it is always around 75 dB
I am trying to re-calibrate my Dirac Live but not even able to manage it at 65-70dB because of Msg 210, error code 102, clipping detected :/You can use a separate SPL meter for this and adjust it correct during the DL level process.
For Dirac Live, you must be 30dB above the noise level. It doesn't matter whether it is ambient noise or noise generated by the electronics. 75dB is not enough with a UMIK-1, for example! See self-noise here (57dB(Z)): Link
Thread 'Wharfedale Linton Heritage with Audiophonics HPA-S250NC first REW meauserements' https://audiosciencereview.com/foru...ics-hpa-s250nc-first-rew-meauserements.46058/Which setup?
