gianluca_v
- Joined
- Jun 22, 2025
- Messages
- 16
- Likes
- 10
Hi folks,
Lately, I’ve been noticing a significant shift in the soundstage of my stereo system—specifically, voices and some instruments in the upper-mids and low treble range are clearly pulling to the left of center.
This happens regardless of whether I’m using Dirac correction or not. For context, I’m using an Arcam SA30 driving a pair of Dynaudio Special Forty speakers. I haven’t made any major changes to the room or speaker positioning. The only recent addition is a turntable placed in the cabinet about 30–40 cm behind the speaker baffles. I considered whether the plastic dust cover might be introducing some reflections, but it seems unlikely to cause such a noticeable shift. In fact removing such dust cover does not solve the issue.
I initially suspected an issue with the right speaker and swapped the L/R channels, but the imbalance remained unchanged. I’ve also ruled out hearing issues, as the soundstage is perfectly centered when listening through headphones.
At this point, the only remaining suspect would be the amplifier, but it seems unlikely that a subtle fault would only affect imaging without other symptoms.
To investigate further, I ran a set of measurements using a UMIK-1 mic and REW. I captured each channel separately and then both together, with and without Dirac correction. While I’m no REW expert, I didn’t see dramatic differences in SPL between the channels. Phase alignment isn’t perfect but not wildly off either. The only significant difference I noted is in RT60 around 100 Hz.
Here’s a link to the REW measurements: https://drive.google.com/file/d/13g-9AqNKMySv3sKYinfRd_X18M-BSces/view?usp=sharing
If anyone is willing to take a look and share their thoughts, I’d greatly appreciate it!
Thanks!
Thanks!
