Sometimes the problem is sitting in front of the computer, with the variable it works, thanksDirac gives informations about disabling the noise filter on Windows and reenable it afterwards in his latest changelogs for Dirac Live.
This noise filter might seem to be (at least for some) the cause of those stated timing problems (exclamation marks).
Dirac Live seems to have problems running its later editions on a MAC, as stated in their accompaning informations.
audiosciencereview.com
| Q: | Unexpected W&F spikes on some PCs? | |
| A: | This is a known issue occasionally observed on some Windows PCs (not on Mac). The cause is that the new C# based audio programming interface keeps creating too many small blocks of memory for transferring audio data without reusing them, which significantly increases the workload of the "Garbage Collector" at the system level to recycle them. Normally, this is not a big deal, but the W&F algorithm in this app is rather computation intensive and easily interrupted by a busy CPU, which manifests as intermittent spikes (every few seconds) caused by the audio dropouts. The technical solution is to replace the audio programming interface from C# based to C++ based at the deep lower level. This requires non-trivial work with unpredictable schedule. Before that, users are recommended to use this app on a relatively faster PC, and keep the workload of the PC as low as possible, for example, close other programs that are temporarily not needed when using this app. [Update] Since version 2.4.8, the app is able to use WASAPI audio interface as the second option, which significantly reduced memory garbages. However, it is currently in experimental stage. |
I didn't have any problem with UMIK-1, UMIK-2 and mic I get with my Arcam SA30. All versions of Dirac Live working as expected.just an fyi I’m getting the error with a UMIK-2. I didn’t want people running off blindly buying it as the definitive answer
edit: Also at no point did Dirac or minidsp indicate that umik-1 could be the issue.
I tried the DLBC about 9 months ago with a UMIK-1 and some DIY tri-amp speakers and I got both "?" issue and crazy timing issues. I figured it was a problem with the tri-amp speakers so just gave up. I recently purchased some new speakers, Neuman KH310, and I still have 2 SVS 3000 subs as well as an Earthworks Mic so I tried it again as that is a pretty straight forward set-up. The good news is I didn't get any "?" issues but when DIRAC created the filter it was non-sensical with 121 ms delay, see below. I am really starting to think DLBC is not and may not ever be ready for prime time.
The Earthworks M23 I am using (With a Motu Ultralite MK5 interface) is much higher performance than either the UMIK-1 or UMIK-2 so I doubt that is the issue. Looking a little closer at the measurements I was getting it looks like the HF was rolled off starting at about 3 Khz. I will check all the settings and try again later. Maybe the clock rates are off somehow.I recommend trying a UMIK-2 instead of a UMIK-1 - that solved the delay issue for me. The UMIK-2 has its own clock source hence it is way more precise than the UMIK-1 when it comes to delay measurements.
See more about that in post #225 here and also in another thread here with measurement examples.
Did the calculated delays make sense? That is the biggest problem I have had.I just tried the new beta and I did not have any imprecise measurement errors
I did a 9-point measurement and everything went smoothly, no issues or any kind of error messages whatsoever
I am happy to report that it seems that Dirac finally got fixed - although it would be great to hear from others sharing their experience too
