Denon DCD-900NE Review (CD Player)
Denon makes a big deal about the chassis reducing vibrations.
Maybe I am wrong, but for me “vibration” reduction is right up there in audiophoolishness with speaker cable risers/stands.
Vibration damping is not used for the transport, but for capacitors and coils, which could in theory have microphonic properties. Same for the clock which is piezo-electric (electrical charge in response to mechanical stress). I have been using absorber feet under my DAC for some time now for this exact reason.
But nothing audible. Microphonics in solid state gear is just another FUD issue. Like jitter. It is used to sell un-necessary stuff.
Yes, just another product in the 'I'd like to pretend that I've improved my system' range.
Info from the manual:
But it would painful since the Denon "plays" the USB content like it would play a CD, tracks in the order that it sees them. There's no interface to select folder/subfolder or search for an album/artist/etc... So that's only to be used as an extension of a CD / SACD. Instead of burning a CD, you put one or couple of albums on the drive and listen to it/them.
Thanks everyone for your replies. Big help. I'm sticking with the Sony 800m2 (bought a second one). The Denons,3800, & 1700 seem crippled in comparison regarding file handling.. No argument the 900 and 1700 are built like a tank, but me at 75 now, they'll likely outlive me.
Does the disc drive on the DCD-900NE make audible noise when the disc is playing? I have need of a CD player that will sit rather close by, and it always bothers me when I can hear the disc spinning.
Thank you.
Not that I remember, but I’ll measure and report back.
EDIT: I'm not able to hear it spinning a disc, with my ear at 20cm from the player. I wasn't able to measure a difference in background noise either (which is below 30dBA in my room).
Hello Everyone,
This is a review and detailed measurements of the Denon DCD-900NE stereo player and transport.
I previously reviewed the Marantz CD6007 which is in the same category. So much so that packaging is identical, as well as the remote control, as well as the user guide. All look to be sourced from the same consulting company.
I like testing CD Players, especially older ones, but I'm still in search of a modern one which I could use as kind of reference. So far the Onkyo C-733 has this role, but it's extremely difficult to source since it's 20 years old. So let's see what this Denon has to tell us.
Denon DCD-900NE - Presentation
This is the latest iteration from Denon (as of August 2024) of this player, replacing the previous DCD-800NE. As you can see on the above picture, the look has not changed and has been the same for a long time. Similar to Marantz, I like it a lot.
On the front face no phones output, which is too bad. I guess this explains the lower price when compared to the Marantz. Also, no selection of different filters but we get the now famous Denon specific filtering in an advanced version called "Advance AL32 Processing Plus". We'll deep dive into that, trust me.
As with the Marantz, there is also a USB input which will accept a USB drive and higher resolution files (up to PCM 24bits/192kHz and DSD 5.6MHz).
Back panel shows the essential:
We have RCA out and digital (Otpi + Coax).
Here is a picture of the inside:
We find two power boards, one for the digital section with servo control, decoding and the Denon AL filtering, and one for the analog section with the ESS DAC. Everything seems well organized and looks qualitative.
As opposed to the Marantz, no refined output stage (HDAM) of course, but the audio board is nice with the ESS9018S and OP1692 in the output stage (for I/V and LPF, I guess), to make us happy:
In terms of usage, first impression was rather good. But again similar to the Marantz, I was annoyed by the slowness of the drive. Indeed, if going forward is relatively fast (but no where near older players), going backwards was a little nightmare. less so than with the Marantz though.
Really, out of the box, these two players are alike.
Denon DCD-900NE - Measurements (Analog out - From CD)
From now on, I will be consistent with my measurements as I described them on the Onkyo C-733 review. So over time, this will help comparing the items I reviewed.
The Denon DC-900NE outputs 2.402Vrms, that is 1.6dB above the standard 2Vrsm. The two channels were matched at 0.01dB (very good). The single-ended outputs invert absolute polarity.
Let's start with the standard 999.91Hz sine @0dBFS (without dither) from my test CD (RCA out):
Left and right channels are shown but only one gets evaluated in that view. Both channels have the same performances, though. Plot is on H2 (-114.7dBr and -115.2dBr).
Well, it is the lowest THD I ever measured from a CD player (-114dB), a huge 18dB better than the Marantz!
THD+N is limited (and so is the SINAD) the resolution of CD Audio. It's the best we can get.
Same view but at -6dBFS now:
Other results (not shown) are:
  • Crosstalk : -137dB at 1kHz, -120dB at 10kHz
  • IMD AES : -97dB (18kHz+20kHz 1:1 @-5dBFS)
  • Pitch Error : 19'997.01Hz (19'997Hz requested) ie +0.00005%
These are extremely good performances for a CD Player, very close to that of the Marantz.
The Denon is a very quiet CD player, doing even better than the Marantz:
We can see only one power supply–related spuria in its output, below -130dB at 50Hz (I live in Switzerland). This is nice to see.
Note the very low level side bands on the two views above, around 1kHz. They are power supply modulation at -130dBr (inaudible, negligible).
Bandwidth measurement (now measured from periodic white noise) shows a significant roll-off at 20kHz (-2dB) starting very early (at 4kHz):
Of course, this is due to the oversampling filter which we will analyze soon. The two channels are perfectly matched, well done.
Before talking filter, multitone test showed no issue:
CD Audio content is safe from distortion, no surprise considering the previous results.
Jitter is absent too, exhibiting a beautiful trace:
Red trace is what is on the test CD (digital output), it can’t be better. The Denon (blue trace) does not add any jitter.
And I forgot to add one of my favorite measurements, and that is the THD (excluding noise) vs Frequency at @-12dBFS:
The Denon had no issue except a little and unusual increase from 8kHz. The two channels showed same excellent performances anyways, best I measured, but this test is easy for 1bit DACs. I like this measurement because it shows lack of linearity already at this level with older R2R architectures that I enjoy testing.
Started with the Teac VRDS-20 review, and on your request + support to get it done (more here), I'm adding now an "intersample-overs" test which intends to identify the behavior of the digital filtering and DAC when it come to process near clipping signals. Because of the oversampling, there might be interpolated data that go above 0dBFS and would saturate (clip) the DAC and therefore the output. And this effect shows through distorsion (THD+N measurement up to 96kHz):
Intersample-overs tests
Bandwidth of the THD+N measurements is 20Hz - 96kHz
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
Teac VRDS-20
-30.7dB​
-26.6dB​
-17.6dB​
Yamaha CD-1 (Non-Oversampling CD Player)
-79.6dB​
-35.3dB​
-78.1dB​
Onkyo C-733
-79.8dB​
-29.4dB​
-21.2dB​
Denon DCD-900NE
-34.2dB
-27.1dB
-19.1dB
I kept some references and will keep the same for other reviews, so you can quickly compare. The results of the Denon DCD-900NE mean the oversampling filter does not have headroom to prevent intersample-overs. The Yamaha CD-1 shines here because it's old enough not to have an oversampling filter.
Denon DCD-900NE - AL32 measurements
I think the Denon proprietary oversampling filter deserves a specific section, as it finds its roots back 3 decades ago.
As @bolserst wrote some time ago ago about Denon filtering, the first iteration of ALPHA processing by Denon featured an automatic filter selection based on LSB toggling, and which I could replicate too. Subsequent version of ALPHA processing included further intelligence in terms of filter selection.
I'll try to keep this section as simple as I can, but it's a challenge.
First, this is the filter response (from periodic white noise) overlaid with the standard AES IMD test (18kHz + 20kHz) which a lot of reviewers like to use:
For the moment, please forget about the filter response (in red) between 60k and 72kHz.
Those of you used to perform and look at these tests will see an impossibility here. It is an obviously slow filter, and so it's not logical to see total absence of aliases of 18kHz and 20kHz (which would be at 26.1kHt and 24.1kHz respectively). That is because the Denon (its AL32 filter) recognizes the typical test tones and switches to a sharp filter in that case, which would make people like me theoretically happy. Fail :)
To counter the test detection by the AL32 filter, it is enough to add a third test tone with this standard AES test. So adding a 80Hz test tone defeats the detection of the filter, and here below we get what we should:
And tadaa, this time we see what's logical with a slow filter response, aliases of 18kHz and 20kHz replicate around 22.05kHz. So you find them 26.1k and 24.1k respectively. I tested all standard AES, DIN, etc..., and when necessary, the AL32 filter switches to a sharper mode to exhibit what testers like to see : absence of aliases out of band.
Also, as with first iteration of ALPHA processing, it detects square signals and switches to NOS (Non Oversampling) mode in that case. This allows Denon to show perfect square waves. When looking at the same in frequency domain, we get this:
This is beautiful and could be used by a teacher at the university to talk about D/A conversion and its effect on creating aliases, enveloped into a sinc function. This garbage is on purpose, again to show perfect square waves, when requested.
The two filter modes I showed, Sharp and NOS, are not activated during music playback. Their purpose is to shine during very specific tests.
How long as it been going on? I don't know, but I can tell you that the SACD DCD-SA1 (22kg of tech from 2005) exhibits the exact same behavior. I am your father:
Proof? Yes of course, my pleasure:
Same slow filter, and same action switching to sharp filter when detection an AES IMD test, haha.
By the way, good to see that the son (DCD-900NE) improves the filter attenuation overall (see the green spikes of the SA1 going higher), even if keeping that strange bump between 62k and 72kHz. On one side it is good to see high end technology of 20 years ago, sold at a crazy price at the time, making its way to budget CD player, thanks Denon. And if you think the DCD-SA1 was a killing machine (I do), go grab a DCD-900NE and enjoy!
Oh, I almost forgot the essential, with music as well as with white or pink noise, the Denon uses the standard slow filter, there's no switching between filters when playing music. Below is an overlay of long term capture (peaks) of the song "Fast Car" from Tracy Chapman and pink noise:
This shows what happens in real life, with real music content (dark green). The remaining energy of aliases at 62k-72kHz are at -100dBr, basically not of any concerns.
I think it closes this chapter.
Denon DCD-900NE - Measurements (Optical Out - From CD)
I measured the digital output of the player, from my test CD, for those who'd like to use it as a transport. The below view shows what's on the CD:
It can't be better than that, This is what's recorded on my test CD. This is also one of the most stable digital output I encountered.
This, and other measurements I performed on its digital outputs, made me confident that the Denon is a prefect transport for those who want to use it with an external DAC.
Denon DCD-900NE - Measurements (USB In - RCA out)
And to finish, very quick feedback about using the USB input with higher resolution files. The THD does not change (of course) and the noise improves because of the bitdepth increase. Unfortunately, with "only" 2.5Vrms output from the output of Denon (RCA), my interface (Motu ultralite mk5) reaches rapidly its limits (because of no auto ranger like an AP, it would be much more at ease with 5Vrms at least and from TRS connections) and so I essentially measure its noise floor:
I think the SINAD would be better than shown here (-103dB) as again limited by the raised noise floor from my interface (I had to push the input gain by 14dB!).
On a filtering perspective, both with PCM 96kHz and 192kHz sampling rate, I can't see any issue (I can't capture at higher rate than 192kHz which limits the view to 96kHz only):
We can only see here the attenuation with 96kHz input file, and that is around 100dB, which is good.
I did not test with DSD files as I don't have any test files of that type. I think the Denon is at ease with higher resolution files.
Conclusion
Used as a CD player, in audio band, these are the best results I got so far. All measurements are very close to what's on the test CD, so it can't really get better. The Denon DCD-900NE is also flawless as a transport.
When compared to my older Denon DCD-SA1, the little DCD-900NE did better absolutely everywhere (from CDA), wow! It is really nice to see older mega expensive technology becoming available to more people.
The behavior of the AL32 filtering is funny, designed to shine under measurements. It's been ongoing for a long time, the DCD-S10 was already including some tricks.
All that said, I am happy of what I saw, and this DCD-900NE is a keeper. It becomes my new low cost reference CD Player, awaiting for the one that will beat it (and even regardless of price, good luck).
I hope you enjoyed the long review and, as usual, let me know how to improve and if you have questions. I have recorded all the 44 measurements (and much more) and if you want me to publish others or run one of your choice, feel free to ask.
Flo
Wonderful review! We have an old stereo system from 1996 with a Denon DCM-440/340 CD player, a Denon DRA-565RD AM-FM stereo receiver, and Bose 301 speakers. We are seeking to replace our CD player. Could this Denon DCD-900NE be integrated into our system. I would very much appreciate your reply.
Im not the original poster, but sure, any hifi CD player works with your receiver.
Yes, as @Barry_Sound said, no issue.
Reactions: EJ3
Hello Everyone,
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
Teac VRDS-20
-30.7dB​
-26.6dB​
-17.6dB​
-79.6dB​
-35.3dB​
-78.1dB​
Onkyo C-733
-79.8dB​
-29.4dB​
-21.2dB​
Denon DCD-900NE
-34.2dB
-27.1dB
-19.1dB
Conclusion
Flo
That was a good buy Flo, rich sounding machine. Thanks again.
I have the Denon 600. Like $100 cheaper than the 900. Not sure what the difference is from the 900. A few features?
Looking at pictures of the inside on Denon's site, it seems the 600NE hosts a BB PCM5142 DAC chip. If that's the case, then the performance is lower on THD+N perspective, as documented to be -93dB (with a sine @-1dBFS) and is all dominated by distortion (documented THD = -93dB too), whereas the ESS9018S of the 900NE is documented at either -108dB in voltage mode or -120dB in current mode (and for a sine @0dBFS).
So they are two very different beasts. I measured a THD+N of -96dB with the 900NE, limit being the CD Audio format, without shaped dither. But THD only was at -113dB, so that's 20dB less that what Texas Instruments documented for the PCM5142, and that's a huge difference.
Now, THD+N of -93dB is the performance of several decades ago, and was limited by the noise. With noise shaping technique, it’s possible to break the CD Audio noise floor, so it’s too bad if the limit is set by THD.
The Denon 600NE is a fine CD player. It's really hard to hear an audible difference between my Denon 600NE and 900NE. The biggest difference is the lack of a USB interface for digital files and you are limited to RCA and optical out with 600NE. No Coax out on 600NE. But, I never use the USB digital option with a CD player AND using the optical out turns the 600NE into a great CD transport that by passes it's internal DAC. It's a fine CD player and a great transport.
Yeah I use iti strictly to play CD's and since all CD players sound the same it's all about features. I dont need the extra features in the 900. I remember now thats why i bought it vs the 900
@NTTY / Flo,
I'm in the market for a reasonably priced CD player right now so your reviews of the Denon DCD 900NE and Marantz CD6007 were of particular interest to me.
I have a few questions (at the end of the post) regarding the Bandwidth comparison of the Denon DCD-900NE and the Marantz CD 6007 CD players:
From your Review of the Denon DCD-900NE:
You noted in your Marantz CD6007 Review:
Bandwidth measurement was the point where this CD player started to give me some concerns. The two channels are matching at less than 0.05dB (very good). But have a look at the bandwidth between the two filters:
Yes, -5dB at 20kHz for Filter 1... And both have a negative effect starting at 10kHz or before... If the younger ears out here are to perceive a difference, or say smoothness into this player, this is why.
Questions:
1. Shouldn't the -2dB roll-off of the Denon DCD 900NE, given it is starting at as low as around 4kHz, also be a concern, and be heard as a softness or smoothness of the sound? Maybe just as much as the -5dB at 20kHz of the Marantz CD 6007 (perhaps for even "older" ears since the roll-off starts off so much lower in frequency)?
2. Also, what is up with the Denon DCD 900NE also rolling off in the low end as well compared to the Marantz CD 6007?
3a. Is it common for DAC's to not be engineered be flat to 20kHz (ie, start rolling prior to reaching 20kHz)?
3b. Do you think the high frequency roll-off on these units is done on purpose by engineers/manufacturers in an attempt to counter the perception that digital audio is not as warm or smooth as analog?
Curious to your thoughts about this.
Also, to Flo and anyone else that owns both of these models.
4. I've read some comments online previously that the Marantz CD 6007 has a very solid, quiet and silky smooth loading tray mechanism. Do you agree with this? How does the Denon DCD 900NE rate in comparison in this regard?
Questions:
Look at the scale. The response is 0.2 dB down by 13ish kHz (and 20 Hz) and 0.3 dB down by 17ish kHz. 0.3 dB is about the minimum humanly detectable level difference, and it's likely to be a fair bit more at the extremes. So unless you have very young, very good hearing with substantial action above ~18.5 kHz, you might as well consider this dead flat.
Questions:
I can’t reply to that question since it will depend on every individual. From the graph, it’s roughly -0.2dB at 15kHz which I can’t detect into music.
-5dB at 20kHz should not be seen, honestly. Can you hear? I don’t know, but there’s no reason to suffer such attenuation in 2024.
It’s -0.2dB at 20Hz, so even if your speakers and amplifier can go that low, it’s very unlikely to be perceived.
That’s exactly the discussion of the oversampling filter which must compensate for the natural attenuation of the sin(x)/x function when converting digital words into a voltage. The hold function generates an attenuation of -3.92dB at 20kHz without compensation. Compensating more or less is therefore a conscious decision, because that also implies phase changes, out of band attenuation, computing power, heat, costs, marketing BS, ...
To be honest, there’s no reason in 2024 to see anything else but flatness. So if we see it, it’s because someone thinks it’s good or was prevented from “fixing it”.
Also, many modern DACs offer the possibility to chose filters and I think it should be left to the end user to decide which one is their preferred, rather than forcing one to the user.
Not for that reason, no. But for many others I mentioned, yes.
One last could be to “complement” the ADC filter that was used to create the master, because filtering also happens there. So to cope with the uncertainty zone of the ADC at conversion (beyond the Nyquist frequency, and before full out of band attenuation), some say that the DAC filter can too contribute to reduce that area of uncertainty which contains unwanted aliases. Again, and since there’s no way to know what filtering was used to create the master, it’s good to have multiple choices with the DAC.
I’ve never been able to hear a difference between filters, but I believe each one should be provided with the possibility to experience when the DAC allows.
In the case of the Denon, their AL filter has been an engineering and marketing product differentiator for decades…
I think it’s the same. I don’t have the Marantz anymore, I kept the Denon only.
The one of the Denon is completely silent. Solid, I can’t judge, only time would tell but it’s “light” compared to others I have (but not in the same price range I must say). It’s only a feeling though.
In the case of the Denon, their AL filter has been an engineering and marketing product differentiation for decades…
I think it’s the same. I don’t have the Marantz anymore, I kept the Demon only.
IF (and for most of us, I think that it is not) these things are an audible problem, a touch of EQ is a possible solution.
