You should upgrade or use an
alternative browser.
M
The ASR site makes it very easy, I love it. Once upon a time, we had to code in HTML to do the same. Now it’s just pressing “Return”...
M
Yes, it is an effect of the conversion due to zero hold conversion (one digital word is converted to a voltage which is kept constant...
M
@NTTY,
Thanks for the clear and concise replies.
Your method of quoting and replying to questions on a "point-by-point basis" makes...
M
I can’t reply to that question since it will depend on every individual. From the graph, it’s roughly -0.2dB at 15kHz which I can’t...
M
Thanks for pointing out the scale. I didn't notice the Denon and Marantz graphs were at different scales when I made a quick glance...
M
@NTTY
Thanks for the detailed reply.
1. If I understand you correctly, ALL CD specification (16 bit/44.1 kHz) DAC's are down 3.92dB...
M
@NTTY / Flo,
I'm in the market for a reasonably priced CD player right now so your reviews of the Denon DCD 900NE and Marantz CD6007...
Loading…
Loading…
