Denon DCD-900NE Review (CD Player)
@NTTY
Thank you for this in depth review.
I recently got back from a trip to Japan and bought (too) many CDs, so I am now in the need of something to actually play said CDs.
As I've never looked into CD players before I am happy to see I don't have to spend big money to play some CDs and get good results.
Hello Everyone,
This is a review and detailed measurements of the Denon DCD-900NE stereo player and transport.
I previously reviewed the Marantz CD6007 which is in the same category. So much so that packaging is identical, as well as the remote control, as well as the user guide. All look to be sourced from the same consulting company.
I like testing CD Players, especially older ones, but I'm still in search of a modern one which I could use as kind of reference. So far the Onkyo C-733 has this role, but it's extremely difficult to source since it's 20 years old. So let's see what this Denon has to tell us.
Denon DCD-900NE - Presentation
This is the latest iteration from Denon (as of August 2024) of this player, replacing the previous DCD-800NE. As you can see on the above picture, the look has not changed and has been the same for a long time. Similar to Marantz, I like it a lot.
On the front face no phones output, which is too bad. I guess this explains the lower price when compared to the Marantz. Also, no selection of different filters but we get the now famous Denon specific filtering in an advanced version called "Advance AL32 Processing Plus". We'll deep dive into that, trust me.
As with the Marantz, there is also a USB input which will accept a USB drive and higher resolution files (up to PCM 24bits/192kHz and DSD 5.6MHz).
Back panel shows the essential:
We have RCA out and digital (Otpi + Coax).
Here is a picture of the inside:
We find two power boards, one for the digital section with servo control, decoding and the Denon AL filtering, and one for the analog section with the ESS DAC. Everything seems well organized and looks qualitative.
As opposed to the Marantz, no refined output stage (HDAM) of course, but the audio board is nice with the ESS9018S and OP1692 in the output stage (for I/V and LPF, I guess), to make us happy:
In terms of usage, first impression was rather good. But again similar to the Marantz, I was annoyed by the slowness of the drive. Indeed, if going forward is relatively fast (but no where near older players), going backwards was a little nightmare. less so than with the Marantz though.
Really, out of the box, these two players are alike.
Denon DCD-900NE - Measurements (Analog out - From CD)
From now on, I will be consistent with my measurements as I described them in the post “More than we hear”, and as I reported them for the Onkyo C-733 review. Over time, this will help comparing the devices I reviewed.
The Denon DC-900NE outputs 2.402Vrms, that is 1.6dB above the standard 2Vrsm. The two channels were matched at 0.01dB (very good). The single-ended outputs invert absolute polarity.
Let's start with the standard 999.91Hz sine @0dBFS (without dither) from my test CD (RCA out):
Left and right channels are shown but only one gets evaluated in that view. Both channels have the same performances, though. Plot is on H2 (-114.7dBr and -115.2dBr).
Well, it is the lowest THD I ever measured from a CD player (-114dB), a huge 18dB better than the Marantz!
THD+N is limited (and so is the SINAD) the resolution of CD Audio. It's the best we can get.
Same view but at -6dBFS now:
Other results (not shown) are:
  • Crosstalk : -137dB at 1kHz, -120dB at 10kHz
  • IMD AES : -97dB (18kHz+20kHz 1:1 @-5dBFS)
  • Pitch Error : 19'997.01Hz (19'997Hz requested) ie +0.00005%
These are extremely good performances for a CD Player, very close to that of the Marantz.
The Denon is a very quiet CD player, doing even better than the Marantz:
We can see only one power supply–related spuria in its output, below -130dB at 50Hz (I live in Switzerland). This is nice to see.
Note the very low level side bands on the two views above, around 1kHz. They are power supply modulation at -130dBr (inaudible, negligible).
Bandwidth measurement (now measured from periodic white noise) shows a significant roll-off at 20kHz (-2dB) starting very early (at 4kHz):
Of course, this is due to the oversampling filter which we will analyze soon. The two channels are perfectly matched, well done.
Before talking filter, multitone test showed no issue:
CD Audio content is safe from distortion, no surprise considering the previous results.
Jitter is absent too, exhibiting a beautiful trace:
Red trace is what is on the test CD (digital output), it can’t be better. The Denon (blue trace) does not add any jitter.
And I forgot to add one of my favorite measurements, and that is the THD (excluding noise) vs Frequency at @-12dBFS:
The Denon had no issue except a little and unusual increase from 8kHz. The two channels showed same excellent performances anyways, best I measured, but this test is easy for 1bit DACs. I like this measurement because it shows lack of linearity already at this level with older R2R architectures that I enjoy testing.
Started with the Teac VRDS-20 review, and on your request + support to get it done (more here), I'm adding now an "intersample-overs" test which intends to identify the behavior of the digital filtering and DAC when it come to process near clipping signals. Because of the oversampling, there might be interpolated data that go above 0dBFS and would saturate (clip) the DAC and therefore the output. And this effect shows through distorsion (THD+N measurement up to 96kHz):
Intersample-overs tests
Bandwidth of the THD+N measurements is 20Hz - 96kHz
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
Teac VRDS-20
-30.7dB​
-26.6dB​
-17.6dB​
Yamaha CD-1 (Non-Oversampling CD Player)
-79.6dB​
-35.3dB​
-78.1dB​
Onkyo C-733
-79.8dB​
-29.4dB​
-21.2dB​
Denon DCD-900NE
-34.2dB​
-27.1dB​
-19.1dB​
I kept some references and will keep the same for other reviews, so you can quickly compare. The results of the Denon DCD-900NE mean the oversampling filter does not have headroom to prevent intersample-overs. The Yamaha CD-1 shines here because it's old enough not to have an oversampling filter.
Denon DCD-900NE - AL32 measurements
I think the Denon proprietary oversampling filter deserves a specific section, as it finds its roots back 3 decades ago.
As @bolserst wrote some time ago ago about Denon filtering, the first iteration of ALPHA processing by Denon featured an automatic filter selection based on LSB toggling, and which I could replicate too. Subsequent version of ALPHA processing included further intelligence in terms of filter selection.
I'll try to keep this section as simple as I can, but it's a challenge.
First, this is the filter response (from periodic white noise) overlaid with the standard AES IMD test (18kHz + 20kHz) which a lot of reviewers like to use:
For the moment, please forget about the filter response (in red) between 60k and 72kHz.
Those of you used to perform and look at these tests will see an impossibility here. It is an obviously slow filter, and so it's not logical to see total absence of aliases of 18kHz and 20kHz (which would be at 26.1kHt and 24.1kHz respectively). That is because the Denon (its AL32 filter) recognizes the typical test tones and switches to a sharp filter in that case, which would make people like me theoretically happy. Fail :)
To counter the test detection by the AL32 filter, it is enough to add a third test tone with this standard AES test. So adding a 80Hz test tone defeats the detection of the filter, and here below we get what we should:
And tadaa, this time we see what's logical with a slow filter response, aliases of 18kHz and 20kHz replicate around 22.05kHz. So you find them 26.1k and 24.1k respectively. I tested all standard AES, DIN, etc..., and when necessary, the AL32 filter switches to a sharper mode to exhibit what testers like to see : absence of aliases out of band.
Also, as with first iteration of ALPHA processing, it detects square signals and switches to NOS (Non Oversampling) mode in that case. This allows Denon to show perfect square waves. When looking at the same in frequency domain, we get this:
This is beautiful and could be used by a teacher at the university to talk about D/A conversion and its effect on creating aliases, enveloped into a sinc function. This garbage is on purpose, again to show perfect square waves, when requested.
The two filter modes I showed, Sharp and NOS, are not activated during music playback. Their purpose is to shine during very specific tests.
How long as it been going on? I don't know, but I can tell you that the SACD DCD-SA1 (22kg of tech from 2005) exhibits the exact same behavior. I am your father:
Proof? Yes of course, my pleasure:
Same slow filter, and same action switching to sharp filter when detection an AES IMD test, haha.
By the way, good to see that the son (DCD-900NE) improves the filter attenuation overall (see the green spikes of the SA1 going higher), even if keeping that strange bump between 62k and 72kHz. On one side it is good to see high end technology of 20 years ago, sold at a crazy price at the time, making its way to budget CD player, thanks Denon. And if you think the DCD-SA1 was a killing machine (I do), go grab a DCD-900NE and enjoy!
Oh, I almost forgot the essential, with music as well as with white or pink noise, the Denon uses the standard slow filter, there's no switching between filters when playing music. Below is an overlay of long term capture (peaks) of the song "Fast Car" from Tracy Chapman and pink noise:
This shows what happens in real life, with real music content (dark green). The remaining energy of aliases at 62k-72kHz are at -100dBr, basically not of any concerns.
I think it closes this chapter.
Demon DCD-900NE - Testing the drive
What would be good measurements if the drive would not properly read a slightly scratched CD, or one that was created at the limits of the norm? The below tests reply to these questions.
Test typeTechnical testResults
Variation of linear cutting velocityFrom 1.20m/s to 1.40m/sPass
Variation of track pitchFrom 1.5µm to 1.7µmPass
Combined variations of track pitch and velocityFrom 1.20m/s & 1.5µm to 1.40m/s & 1.7µmPass
HF detection (asymmetry pitch/flat ratio)Variation from 2% to 18%Pass
Dropouts resistanceFrom 0.05mm (0.038ms) to 4mm (3.080ms)Up to 2.4mm.
Combined dropouts and smallest pitchFrom 1.5µm & 1mm to 1.5µm & 2.4mmUp to 2.4mm.
Successive dropoutsFrom 2x0.1mm to 2x3mmUp to 2.4mm.
The drive of the Denon DCD-900NE was able to consistently continue playing, and without generating typical digital clicks, with dropouts of up to 2.4mm. The interpolation effect remained hidden to my hears when it kicked-off and the Denon did not fail to maintain a constant flow with up to 3mm dropouts (with lots of clicks). The DCD-900NE had no issue with variable linear velocity and/or track pitch, as well as with HF detection. This is a very good drive.
Denon DCD-900NE - Measurements (Optical Out - From CD)
I measured the digital output of the player, from my test CD, for those who'd like to use it as a transport. The below view shows what's on the CD:
It can't be better than that, This is what's recorded on my test CD. This is also one of the most stable digital output I encountered and that is because of the very precise clock at the digital output, so precise that it is below what I can measure (which is 0.5ppm).
Stereophile was often using the 3DC measurement as a proof of low noise DAC. It is from an undithered 1kHz sine at -90.31dBFS. With 16bits, the signal should appear (on a scope) as the 3DC levels of the smallest symmetrical sign magnitude digital signal. I am reusing this test as a further proof of no alteration of the digital signal at the output, as it's proven to be a revealing tests with several non "bit-perfect" drives. This is the result with the Denon DCD-900NE:
You can clearly see the three DC levels -1, 0, +1 repeating. Indeed, at such a low digital level, there's only one bit to represent the signal, and so it's either negative, positive or 0. So the system cannot reproduce a sine wave, because there's just one bit on and off for a period of time. It therefore creates a square wave, which we see "suffering" from the Gibbs Phenomenon due to the band limited (22.05kHz max) representation of the Audio CD.
This, and other measurements I performed on its digital outputs, made me confident that the Denon is a prefect transport for those who want to use it with an external DAC.
Denon DCD-900NE - Measurements (USB In - RCA out)
And to finish, very quick feedback about using the USB input with higher resolution files. The THD does not change (of course) and the noise improves because of the bitdepth increase. Unfortunately, with "only" 2.5Vrms output from the output of Denon (RCA), my interface (Motu ultralite mk5) reaches rapidly its limits (because of no auto ranger like an AP, it would be much more at ease with 5Vrms at least and from TRS connections) and so I essentially measure its noise floor:
I think the SINAD would be better than shown here (-103dB) as again limited by the raised noise floor from my interface (I had to push the input gain by 14dB!).
On a filtering perspective, both with PCM 96kHz and 192kHz sampling rate, I can't see any issue (I can't capture at higher rate than 192kHz which limits the view to 96kHz only):
We can only see here the attenuation with 96kHz input file, and that is around 100dB, which is good.
I did not test with DSD files as I don't have any test files of that type. I think the Denon is at ease with higher resolution files.
Conclusion
Used as a CD player, in audio band, these are the best results I got so far. All measurements are very close to what's on the test CD, so it can't really get better. The Denon DCD-900NE is also flawless as a transport.
When compared to my older Denon DCD-SA1, the little DCD-900NE did better absolutely everywhere (from CDA), wow! It is really nice to see older mega expensive technology becoming available to more people.
The behavior of the AL32 filtering is funny, designed to shine under measurements. It's been ongoing for a long time, the DCD-S10 was already including some tricks.
All that said, I am happy of what I saw, and this DCD-900NE is a keeper. It becomes my new low cost reference CD Player, awaiting for the one that will beat it (and even regardless of price, good luck).
I hope you enjoyed the long review and, as usual, let me know how to improve and if you have questions. I have recorded all the 44 measurements (and much more) and if you want me to publish others or run one of your choice, feel free to ask.
Flo
Hi, as a transport you tested this Denon DCD-900NE with the optical digital output. What about the coaxial digital output? Is coaxial better? Coaxial is 1 difference between this 900 and the cheaper 600 which only has optical digital out. When optical is the same as coaxial or even better the Denon DCD-600NE is a good choice too I guess?
At the time I used the optical output indeed. I don’t recall using the coax out. Coaxial is not better. I can run the same test if you want, it should show the same results (maybe we could get ground loop issue from the electric connection or the coax cable though, compared to optical).
I can’t tell you about the 600NE, but we can guess so, as I don’t see any reasons to have more processing before digital output, but sometimes I get bad surprises.
The Denon 600NE will work however there are differences even when used only as a transport.
The DCD-900NE offers several notable upgrades.
1. Mechanically: 900NE offers a more robust/quieter transport with excellent vibration control.
2. The internal layout is improved, with greater physical separation between power and audio boards.
3. The 900NE adds a precise master clock system adjacent to the DAC for suppressing jitter.
4. 900NE build quality is a step up: with substantial aluminum front panel, heavier chassis, and raised feet for further vibration isolation.
Thanks! This is exactly the information I was looking for.
So may I conclude the Denon DCD-900NE is almost the same as the Marantz CD-6007? And they are both very good and score almost the same in soundquality and as a transport with digital out to a DAC?
Hello,
I have been interested in the DCD-900NE but have a couple older discs that were mastered with pre-emphasis. I recently asked Denon if this player applies de-emphasis. Here was their response:
Q: Does the DCD-900NE apply de-emphasis to older Redbook CDs that use pre-emphasis?
A: Hello Brian,With how far digital to analog circuitry has come in recent years, de-emphasis is no longer required when playing back CDs made with emphasis encoding.With the DCD-900NE you can play all of your RedBook CDs with confidence, with or without emphasis encoding.
By Denon Team
Doesn't exactly make feel super confident before dropping $600 on this. Does anyone here have a pre-emphasis album they can or have tested on the DCD-900NE and can confirm if it decodes properly? I really want this player, but also need it to play discs correctly.
Thanks to anyone who can assist!
Brian
A test for the correct decoding of pre-emphasised CDs would add great value to your already great CD reviews!
Hello,
By Denon Team
Brian
That is a bizarre response from Denon. It basically says “we don’t apply de-emphasis but don’t worry about it.”
Hi @NTTY!
I noticed you have updated the 999.9x Hz @ 0dFS FFT graph in your review with a new one.
There are significant differences between the first and second FFT:
Screenshot 2025-08-15 at 22-05-02 Denon DCD-900NE Review (CD Player) Audio Science Review (ASR...png
By the way, the text underneath the FFT graph seems to not match the harmonic levels calculated by your software (H2 at -129,6 dB and not at -114.7dBr neither at -115.2dBr).
Is the fact that the original FFT was made with a dithered test signal off your test CD and the second one with an undithered signal the only difference that explained the discrepancy from one measurement to the other or did something else changed in the test methodology? What are the 0 dB reference of the level of the harmonics on both graph, new and old ?
I think I updated these 3 times.
The one you show, and from the text of the graph was indeed from an old file, 1kHz with dither from REW. That explains the limited SNR at 93dB instead of 98dB now because REW’s dither occupies 1LSB (6dB loss in the process). At this time, I was using the Motu Ultralite Mk5 for measurements, which explains a little more distortion.
So yes, now it is 999.91Hz without dither, and measurement from the E1DA ADCiso.
When I use dither, it’s now the one of Audacity (Rectangle dither) which consumes only 0.5LSB. But I don’t show these measurements although I perform them. Else I use shape dither from Audacity too, as you know.
Last and not least, I’m now using the beta Version of REW which includes a correction in ENOB calculation to not account for the headroom of the ADC.
Distortion is calculated relative to the detected test tone (the carrier) in REW, that’s why it’s important to correctly set the generator, as if it was sending the signal, since the CD player is the generator itself via the test CD.
Thanks for spotting the miss about the text. I thought I updated everything but forgot that.
I bought the Denon DCD-900E as part of a special offer! I really like the music playback!
What I miss with the Denon DCD-900E is that you can't open or close the CD tray with the Denon universal remote control.
There are no buttons on either the device or the remote control that allow you to scroll forwards or backwards through a piece of music. Is there a trick to this?
There are 'fast forward' and 'rewind' buttons on the fascia, I assume on the remote too?
I think "Denon Team" had no idea what bholder was talking about.
I purchased that cd player recently and I have a CD that was mastered with per-emphasis: Opera sauvage by Vangelis. I confirm that the dcd-900ne supports de-emphasis.
I also did another test just to be 100% sure I wasn't dreaming.
I created a file with white noise and I wrote two tracks on a CDRW, one of them with the pre-emphasis bit set. I ripped both tracks and I compared them with the source file and they were identical. Then I played the CD back with che Denon and they sounded obviously different.
I'm sorry I can't post any measurement because I don't have the cable yet.
Does the Denon DCD-900NE output hi-res (e.g. 24/96 or 24/192) over coax/optical when playing hi-res FLAC files from USB, or is it limited to 16/44.1?
Does the AL32 Processing work on the analog output when playing 16/44.1 FLAC files from USB on the Denon DCD-900NE?
