Denon DCD-900NE Review (CD Player)
@NTTY
Thanks for the detailed reply.
1. If I understand you correctly, ALL CD specification (16 bit/44.1 kHz) DAC's are down 3.92dB at 20kHz intrinsically (mathematically)?
So any deviation of that from any player is done with engineering manipulation of the signal. In the case of the Denon the filter is purposely designed to start rolling off at around 4kHz, so it can "slowly" roll off to about -2dB at 20kHz. Whereas the Marantz was designed to start rolling off "later" but "faster" such that it is about -5dB at 20kHz. So the Marantz is actually purposely designed (or was poorly designed) to be down not only to -5dB, but about 1dB more (5dB-3.92dB) than what is expected naturally to happen (which makes no sense as to why they would do that- or be content with that- at least to me anyway:). Is my analysis correct or am I way off in my understanding?
2. So it looks like I didn't notice (thanks for pointing that out @AnalogSteph) that the scale of the graph for the Marantz and Denon were not the same (Denon is displayed more zoomed in).
So if presented in the same scale, is the roll-off in the Low End frequencies as seen in the Marantz similar to the small amount shown with the Denon? Is the Denon frequency response mild roll off in the low end (20Hz-60Hz) pretty representative for what you would expect from most players?
3. There was one additional thing I forgot to ask in my original post. Did you measure (or if not, could you) the Error Correction capability (Pierre Verany Digital Test CD ) of the Denon DCD 900NE?
Obviously all players should pass the CD standard of up to 0.2mm in length spiral gaps. But some go significantly beyond that (e.g. 1.5mm, or two closely space gaps at 1.0mm in length) until audible glitches become present. I think it would be helpful to include the maximum measure gaps in all of you reviews if possible.
I suppose the fact that you got rid of the Marantz CD 6007 but kept the Denon DCD 900NE implies you preferred the Denon over it I guess. (not saying that means the Marantz is junk).
I really appreciate you taking the time to provide the reviews you are doing. We need more objective testing of audio gear. You just can't trust the marketing nonsense from manufacturers. Less audio magazines exist that measure audio products. For the ones that do still exist, people need to look out for shady subjective reviews/publishers opinions done for personal gain (and don't get me started with many YouTube audio channel reviewers for the same reason, etc). Plus, with so few Audio Retail stores available locally in anything but the largest cities/markets, it makes it difficult or impossible to personally to see, listen and touch these products to make informed purchase decisions. We are left almost totally blind. Thank you so much for your dedication and passion for doing these tests, sharing them, and answering questions. While it seems obvious you enjoy doing it, it still takes time. A tip of the cap from me:)
PS: Just curious if you can let forum readers know what software/equipment you use to test the equipment (my apologies if this is noted somewhere else in the forum).
Look at the scale. The response is 0.2 dB down by 13ish kHz (and 20 Hz) and 0.3 dB down by 17ish kHz. 0.3 dB is about the minimum humanly detectable level difference, and it's likely to be a fair bit more at the extremes. So unless you have very young, very good hearing with substantial action above ~18.5 kHz, you might as well consider this dead flat.
Thanks for pointing out the scale. I didn't notice the Denon and Marantz graphs were at different scales when I made a quick glance comparison of their graphs.
@NTTY
Yes, it is an effect of the conversion due to zero hold conversion (one digital word is converted to a voltage which is kept constant until next word comes in). This mechanism envelopes the output signal in a sin(x)/x function which generated a -3.92dB attenuation at 20khz.
Yes, in digital domain (before conversion) or in analog domain (after conversion).
Yes, that is what they wanted (I hope :))
Yep
Correct. It's probably laziness, one filter for all sampling rates, maybe(?). I can't be sure, but it does not suit Audio CD, too bad for a CD Player.
I added a zoomed view at the time for the Marantz, indeed :)
No, it's less on the Marantz in the low end (like 10x less).
Usually, on modern players, this should be flat.
I have the CD but I did not use it. I can do that but I won't have time before next year, I'm afraid.
Yep, I did not like the higher THD and filter response of the Marantz. On a listening experience perspective, they were the same to me. These two players are otherwise nearly identical, on a end user experience perspective.
Thanks and my pleasure indeed :)
Yep, have a look here. More than equipment, you need the test files correctly created ;)
I will need to document better what test file tells us what, how and why. Currently it's only in an excel I wrote, but I'd like to document much better.
@NTTY,
Thanks for the clear and concise replies.
Your method of quoting and replying to questions on a "point-by-point basis" makes it easy to understand and follow (and as a side benefit, less likely you'll accidentally miss responding to a particular point as well). I suspect other forum readers who are following along the topic thread will find this method helpful as well.
Ok, so this is an example of one area that the Marantz actually did a better job of than the Denon did (flatter response/less rolloff in the low frequency end). Although, as you have pointed out, while there is probably no reason for modern players like the Denon (or others for that matter) to not be flatter, the value is quite small, and likely not audible.
That's completely understandable. Yes, if you do get a chance to test the Error Correction specs at some point that would be nice.
I think it would be a helpful to include the Error Correction test in all of your Reviews.
It just adds another data point to compare players and for many people might be a very "practical" spec to know; given aging CD's and the increased likelihood of getting scratched discs via the used markets.
Thank you! Really cool to see your passion. Great stuff to know for the more adventurous types that might want to do some of their own testing. I'd be interested in trying. I'm just not sure if I have the technical chops to understand it and to do it (I've only just glanced at your first post of the topic/thread you linked so far). Very impressed with the time you dedicated to creating your own Test CD. Will look forward to seeing you improve the Documentation (Too bad we don't have unlimited time) :)
Just a guess, but you must have math or science background/job.
@NTTY,
The ASR site makes it very easy, I love it. Once upon a time, we had to code in HTML to do the same. Now it’s just pressing “Return” button: so much time saved. And I see you went the next level of sub-quoting :)
Exact. And why the Denon has that small inflection in low frequency is to be left to Denon engineers. Maybe that saved few cents and they know it’s of no influence for the customer.
I have a personal interest to play with that too, so I’ll give the priority to the Denon ;)
In the future, yep. For those I already reviewed, I doubt, although I have tried to keep the reviews updated with the latest test set. But that’s crazy time consuming, and of little reward.
Yep, valid ask indeed. That’s why I searched and bought that CD at the cost of a crazy good DAC ;)
Thanks, recognition is a very good reward. And I must mention my mentors: @restorer-john and @AnalogSteph for always pushing me further.
Good guess ;)
Hello Everyone,
This is a review and detailed measurements of the Denon DCD-900NE stereo player and transport.
I previously reviewed the Marantz CD6007 which is in the same category. So much so that packaging is identical, as well as the remote control, as well as the user guide. All look to be sourced from the same consulting company.
I like testing CD Players, especially older ones, but I'm still in search of a modern one which I could use as kind of reference. So far the Onkyo C-733 has this role, but it's extremely difficult to source since it's 20 years old. So let's see what this Denon has to tell us.
Denon DCD-900NE - Presentation
This is the latest iteration from Denon (as of August 2024) of this player, replacing the previous DCD-800NE. As you can see on the above picture, the look has not changed and has been the same for a long time. Similar to Marantz, I like it a lot.
On the front face no phones output, which is too bad. I guess this explains the lower price when compared to the Marantz. Also, no selection of different filters but we get the now famous Denon specific filtering in an advanced version called "Advance AL32 Processing Plus". We'll deep dive into that, trust me.
As with the Marantz, there is also a USB input which will accept a USB drive and higher resolution files (up to PCM 24bits/192kHz and DSD 5.6MHz).
Back panel shows the essential:
We have RCA out and digital (Otpi + Coax).
Here is a picture of the inside:
We find two power boards, one for the digital section with servo control, decoding and the Denon AL filtering, and one for the analog section with the ESS DAC. Everything seems well organized and looks qualitative.
As opposed to the Marantz, no refined output stage (HDAM) of course, but the audio board is nice with the ESS9018S and OP1692 in the output stage (for I/V and LPF, I guess), to make us happy:
In terms of usage, first impression was rather good. But again similar to the Marantz, I was annoyed by the slowness of the drive. Indeed, if going forward is relatively fast (but no where near older players), going backwards was a little nightmare. less so than with the Marantz though.
Really, out of the box, these two players are alike.
Denon DCD-900NE - Measurements (Analog out - From CD)
From now on, I will be consistent with my measurements as I described them on the Onkyo C-733 review. So over time, this will help comparing the items I reviewed.
The Denon DC-900NE outputs 2.402Vrms, that is 1.6dB above the standard 2Vrsm. The two channels were matched at 0.01dB (very good). The single-ended outputs invert absolute polarity.
Let's start with the standard 999.91Hz sine @0dBFS (without dither) from my test CD (RCA out):
Left and right channels are shown but only one gets evaluated in that view. Both channels have the same performances, though. Plot is on H2 (-114.7dBr and -115.2dBr).
Well, it is the lowest THD I ever measured from a CD player (-114dB), a huge 18dB better than the Marantz!
THD+N is limited (and so is the SINAD) the resolution of CD Audio. It's the best we can get.
Same view but at -6dBFS now:
Other results (not shown) are:
  • Crosstalk : -137dB at 1kHz, -120dB at 10kHz
  • IMD AES : -97dB (18kHz+20kHz 1:1 @-5dBFS)
  • Pitch Error : 19'997.01Hz (19'997Hz requested) ie +0.00005%
These are extremely good performances for a CD Player, very close to that of the Marantz.
The Denon is a very quiet CD player, doing even better than the Marantz:
We can see only one power supply–related spuria in its output, below -130dB at 50Hz (I live in Switzerland). This is nice to see.
Note the very low level side bands on the two views above, around 1kHz. They are power supply modulation at -130dBr (inaudible, negligible).
Bandwidth measurement (now measured from periodic white noise) shows a significant roll-off at 20kHz (-2dB) starting very early (at 4kHz):
Of course, this is due to the oversampling filter which we will analyze soon. The two channels are perfectly matched, well done.
Before talking filter, multitone test showed no issue:
CD Audio content is safe from distortion, no surprise considering the previous results.
Jitter is absent too, exhibiting a beautiful trace:
Red trace is what is on the test CD (digital output), it can’t be better. The Denon (blue trace) does not add any jitter.
And I forgot to add one of my favorite measurements, and that is the THD (excluding noise) vs Frequency at @-12dBFS:
The Denon had no issue except a little and unusual increase from 8kHz. The two channels showed same excellent performances anyways, best I measured, but this test is easy for 1bit DACs. I like this measurement because it shows lack of linearity already at this level with older R2R architectures that I enjoy testing.
Started with the Teac VRDS-20 review, and on your request + support to get it done (more here), I'm adding now an "intersample-overs" test which intends to identify the behavior of the digital filtering and DAC when it come to process near clipping signals. Because of the oversampling, there might be interpolated data that go above 0dBFS and would saturate (clip) the DAC and therefore the output. And this effect shows through distorsion (THD+N measurement up to 96kHz):
Intersample-overs tests
Bandwidth of the THD+N measurements is 20Hz - 96kHz
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
Teac VRDS-20
-30.7dB​
-26.6dB​
-17.6dB​
Yamaha CD-1 (Non-Oversampling CD Player)
-79.6dB​
-35.3dB​
-78.1dB​
Onkyo C-733
-79.8dB​
-29.4dB​
-21.2dB​
Denon DCD-900NE
-34.2dB
-27.1dB
-19.1dB
I kept some references and will keep the same for other reviews, so you can quickly compare. The results of the Denon DCD-900NE mean the oversampling filter does not have headroom to prevent intersample-overs. The Yamaha CD-1 shines here because it's old enough not to have an oversampling filter.
Denon DCD-900NE - AL32 measurements
I think the Denon proprietary oversampling filter deserves a specific section, as it finds its roots back 3 decades ago.
As @bolserst wrote some time ago ago about Denon filtering, the first iteration of ALPHA processing by Denon featured an automatic filter selection based on LSB toggling, and which I could replicate too. Subsequent version of ALPHA processing included further intelligence in terms of filter selection.
I'll try to keep this section as simple as I can, but it's a challenge.
First, this is the filter response (from periodic white noise) overlaid with the standard AES IMD test (18kHz + 20kHz) which a lot of reviewers like to use:
For the moment, please forget about the filter response (in red) between 60k and 72kHz.
Those of you used to perform and look at these tests will see an impossibility here. It is an obviously slow filter, and so it's not logical to see total absence of aliases of 18kHz and 20kHz (which would be at 26.1kHt and 24.1kHz respectively). That is because the Denon (its AL32 filter) recognizes the typical test tones and switches to a sharp filter in that case, which would make people like me theoretically happy. Fail :)
To counter the test detection by the AL32 filter, it is enough to add a third test tone with this standard AES test. So adding a 80Hz test tone defeats the detection of the filter, and here below we get what we should:
And tadaa, this time we see what's logical with a slow filter response, aliases of 18kHz and 20kHz replicate around 22.05kHz. So you find them 26.1k and 24.1k respectively. I tested all standard AES, DIN, etc..., and when necessary, the AL32 filter switches to a sharper mode to exhibit what testers like to see : absence of aliases out of band.
Also, as with first iteration of ALPHA processing, it detects square signals and switches to NOS (Non Oversampling) mode in that case. This allows Denon to show perfect square waves. When looking at the same in frequency domain, we get this:
This is beautiful and could be used by a teacher at the university to talk about D/A conversion and its effect on creating aliases, enveloped into a sinc function. This garbage is on purpose, again to show perfect square waves, when requested.
The two filter modes I showed, Sharp and NOS, are not activated during music playback. Their purpose is to shine during very specific tests.
How long as it been going on? I don't know, but I can tell you that the SACD DCD-SA1 (22kg of tech from 2005) exhibits the exact same behavior. I am your father:
Proof? Yes of course, my pleasure:
Same slow filter, and same action switching to sharp filter when detection an AES IMD test, haha.
By the way, good to see that the son (DCD-900NE) improves the filter attenuation overall (see the green spikes of the SA1 going higher), even if keeping that strange bump between 62k and 72kHz. On one side it is good to see high end technology of 20 years ago, sold at a crazy price at the time, making its way to budget CD player, thanks Denon. And if you think the DCD-SA1 was a killing machine (I do), go grab a DCD-900NE and enjoy!
Oh, I almost forgot the essential, with music as well as with white or pink noise, the Denon uses the standard slow filter, there's no switching between filters when playing music. Below is an overlay of long term capture (peaks) of the song "Fast Car" from Tracy Chapman and pink noise:
This shows what happens in real life, with real music content (dark green). The remaining energy of aliases at 62k-72kHz are at -100dBr, basically not of any concerns.
I think it closes this chapter.
Denon DCD-900NE - Measurements (Optical Out - From CD)
I measured the digital output of the player, from my test CD, for those who'd like to use it as a transport. The below view shows what's on the CD:
It can't be better than that, This is what's recorded on my test CD. This is also one of the most stable digital output I encountered.
This, and other measurements I performed on its digital outputs, made me confident that the Denon is a prefect transport for those who want to use it with an external DAC.
Denon DCD-900NE - Measurements (USB In - RCA out)
And to finish, very quick feedback about using the USB input with higher resolution files. The THD does not change (of course) and the noise improves because of the bitdepth increase. Unfortunately, with "only" 2.5Vrms output from the output of Denon (RCA), my interface (Motu ultralite mk5) reaches rapidly its limits (because of no auto ranger like an AP, it would be much more at ease with 5Vrms at least and from TRS connections) and so I essentially measure its noise floor:
I think the SINAD would be better than shown here (-103dB) as again limited by the raised noise floor from my interface (I had to push the input gain by 14dB!).
On a filtering perspective, both with PCM 96kHz and 192kHz sampling rate, I can't see any issue (I can't capture at higher rate than 192kHz which limits the view to 96kHz only):
We can only see here the attenuation with 96kHz input file, and that is around 100dB, which is good.
I did not test with DSD files as I don't have any test files of that type. I think the Denon is at ease with higher resolution files.
Conclusion
Used as a CD player, in audio band, these are the best results I got so far. All measurements are very close to what's on the test CD, so it can't really get better. The Denon DCD-900NE is also flawless as a transport.
When compared to my older Denon DCD-SA1, the little DCD-900NE did better absolutely everywhere (from CDA), wow! It is really nice to see older mega expensive technology becoming available to more people.
The behavior of the AL32 filtering is funny, designed to shine under measurements. It's been ongoing for a long time, the DCD-S10 was already including some tricks.
All that said, I am happy of what I saw, and this DCD-900NE is a keeper. It becomes my new low cost reference CD Player, awaiting for the one that will beat it (and even regardless of price, good luck).
I hope you enjoyed the long review and, as usual, let me know how to improve and if you have questions. I have recorded all the 44 measurements (and much more) and if you want me to publish others or run one of your choice, feel free to ask.
Flo
Hi Flo,
First of all, thank you for you exhaustive and detailed review of DCD-900NE.
Data should not lie to us, but our ears also don't.
I must disagree with the positive subjective (maybe also objective reviews) on this cdp.
I'm a owner of one of it for 2 months and honestly I don't understand why all the fuss around this equipment.
Being a long term cd advocate, with more than one cdp (from low budget equipment to 10x the price of the Dcd-900ne) on my hands, the Denon unit is, in my opinion, a below average one, maybe due to high expectations from a modern unit arguably with so much care taken to sound tuning, vibration control etc.
Maybe it makes a nice partnership with PMA range of amplifiers, and that was Denon purpose.
As a "standalone" unit, my recommendation is that you ear it before buy it, or buy it with a good return policy.
Cheers
RA
Can you please provide us measurements of the same kind NTTY has performed on his unit to back up your disagreement with his objective review ?
Hi Flo,
Without being more specific, it will be hard to correlate your perception with measurements which are all above excellent for a CD player, far beyond "average", to the exception of the roll-off generated by the AL32 filter at high frequencies.
No, there's nothing specific between these two, Denon respects the "standards", like voltage output, voltage input sensitivity, output/input impedance, as they and many other manufacturers have been doing for decades, so they don't specifically pair (and if they would, we could see that very clearly in measurements).
Cheers
RA
That is not a bad recommendation, everyone can have a perception and decide based upon it.
I don't have any.
However, I don't see any reason to doubt Flo's excellent analysis.
My opinion, based on perception as a owner, comparing this cdp with many others I've had/some I have, is the one I've set out above.
Perhaps this is one of those cases where a piece of equipment with excellent measurements, nice reviews and apparently well thought out in terms of engineering (that's what convinced me), fails as a proper musical reprodution device.
If you do not have any measurement and don't see any reason to doubt NTTY's analysis, why did you wrote that you "must disagree [...] (with maybe also objective review) of this cdp" ?
‘Patience is the companion of wisdom.’ – Saint Augustine
I don't have any.
Perhaps yours is defective? That has been known to happen.
Then, again, we just like what we like (and don't like what we don't) in varying degrees, for whatever reason
Hello Everyone,
From now on, I will be consistent with my measurements as I described them in the post “More than we hear”, and as I reported them for the Onkyo C-733 review. Over time, this will help comparing the devices I reviewed.
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
Teac VRDS-20
-30.7dB​
-26.6dB​
-17.6dB​
-79.6dB​
-35.3dB​
-78.1dB​
Onkyo C-733
-79.8dB​
-29.4dB​
-21.2dB​
Denon DCD-900NE
-34.2dB
-27.1dB
-19.1dB
Conclusion
Flo
I am currently running the Denon DCD-900NE into my Fiio R2R dac then into the Denon PM900HNE with excellent results. A more straightforward connection from the player to the amp via Coaxial is also very satisfactory indeed (ESS9018 x ESS9018-Player/CD) and I found nothing to complain about. Running it again with the same Van Damme Plasma Coaxial cable through the Fiio R2R and the same cable (VanDammePlasma) used for the line out to the amp opens the soundstage a little more using the OS filter on the dac. Very nice combination and I have no intention of upgrading anything in the near future. I will say however shoving the Fiio R2R or an equivalent R2R structure into the Denon pma900hne amp itself would be a instant purchase for me personally in any future iteration but the ESS9018 is good enough for me and both units sound superb out of the box as is.
Does the disc drive on the DCD-900NE make audible noise when the disc is playing? I have need of a CD player that will sit rather close by, and it always bothers me when I can hear the disc spinning.
Thank you.
It’s very quiet.
Reactions: EJ3
@NTTY / Flo,
I'm in the market for a reasonably priced CD player right now so your reviews of the Denon DCD 900NE and Marantz CD6007 were of particular interest to me.
I have a few questions (at the end of the post) regarding the Bandwidth comparison of the Denon DCD-900NE and the Marantz CD 6007 CD players:
From your Review of the Denon DCD-900NE:
You noted in your Marantz CD6007 Review:
Bandwidth measurement was the point where this CD player started to give me some concerns. The two channels are matching at less than 0.05dB (very good). But have a look at the bandwidth between the two filters:
Yes, -5dB at 20kHz for Filter 1... And both have a negative effect starting at 10kHz or before... If the younger ears out here are to perceive a difference, or say smoothness into this player, this is why.
Questions:
1. Shouldn't the -2dB roll-off of the Denon DCD 900NE, given it is starting at as low as around 4kHz, also be a concern, and be heard as a softness or smoothness of the sound? Maybe just as much as the -5dB at 20kHz of the Marantz CD 6007 (perhaps for even "older" ears since the roll-off starts off so much lower in frequency)?
2. Also, what is up with the Denon DCD 900NE also rolling off in the low end as well compared to the Marantz CD 6007?
3a. Is it common for DAC's to not be engineered be flat to 20kHz (ie, start rolling prior to reaching 20kHz)?
3b. Do you think the high frequency roll-off on these units is done on purpose by engineers/manufacturers in an attempt to counter the perception that digital audio is not as warm or smooth as analog?
Curious to your thoughts about this.
Also, to Flo and anyone else that owns both of these models.
4. I've read some comments online previously that the Marantz CD 6007 has a very solid, quiet and silky smooth loading tray mechanism. Do you agree with this? How does the Denon DCD 900NE rate in comparison in this regard?
I have the 900 and had the 6007. I can tell you straight off the bat that the 900 is better. Sounds much cleaner. I bought the 6007 and returned it literally one day later and that was partnered with the PM6007 matching amp. The 900 is just a better machine sonically and looks better too. It’s a simple answer but it was also that obvious.
It is very unlikely that these two have such a difference in sound, unless one of them is defective. Even when a DAC looks broken when measuring it, its flaws remain easily masked into music, as I mentioned here.
The Denon and Marantz don’t have the same output level, but it’s small enough not to make a significant difference even without matching levels.
I think it’s been largely demonstrated and published in so many places, for the last decades, that our ears are not very good at spotting anything less than HUGE defects.
So statement like the above can’t be trusted without a pile of data that are impossible to gather in only 24hours.
It may have been a sub par piece in some way or another but honestly the difference in clarity was obvious on this occasion. I also don’t have access to multiple units so I was unable to compare.
No complaints at all with my 900.
Most Denon CD players sound the same when you use the optical out to a quality DAC. This configuration bypasses the internal DAC and the player simply becomes a transport. At that point, what determines which one I prefer is how responsive the load mechanism and remote control is. I also perfer the Denon over the Marantz. Mostly in looks and I appreciate less digital gizmo's on my CD Player.
Ok, cool bit of info there, thanks. I have a Fiio R2R which I will experiment with later. Currently I am using the coaxial to the coaxial input on the Denon PMA900hne and the sound quality does not disappoint at all, both units have the ESS9018 chip.
Do you have even a single example of any (other) device in that category?
