| Track | Title | Measurements | How to |
1 | A_256kMeasSweep_1_to_22050_-12_dBFS_44k_PCM16_LR_refL.wav | Bandwidth, Phase, THD vs Frequency. | Auto setup by test file (44.1kHz, 256k) |
2 | A_256kMeasSweep_1_to_22050_-12_dBFS_44k_PCM16_LR_refR.wav | Bandwidth, Phase, THD vs Frequency. | Auto setup by test file (44.1kHz, 256k) |
3 | B_AES17_18k_20k_1_1_-5_dBFS_44k_PCM16_LR_Dither.wav | IMD AES | Input 24bits/192kHz, FFT length 512k, BH7, 32 Averages |
4 | B_AES17_41_7993_4_1_-5_dBFS_44k_PCM16_LR_Dither.wav | IMD AES | Input 24bits/192kHz, FFT length 512k, BH7, 32 Averages |
5 | B_CCIF_19k_20k_1_1_-5_dBFS_44k_PCM16_LR_Dither.wav | IMD CCIF | Input 24bits/192kHz, FFT length 512k, BH7, 32 Averages |
6 | B_DIN_250_8k_4_1_-3_dBFS_44k_PCM16_LR_Dither.wav | IMD DIN | Input 24bits/192kHz, FFT length 512k, BH7, 32 Averages |
7 | B_ISO-1 [email protected] 0.69dB | Intersample over test | Input 24bits/192kHz, FFT length 512k, BH7, 32 Averages |
8 | B_ISO-2 7350@60 1.25dB | Intersample over test | Input 24bits/192kHz, FFT length 512k, BH7, 32 Averages |
9 | B_ISO-2 11025@45 3dB | Intersample over test | Input 24bits/192kHz, FFT length 512k, BH7, 32 Averages |
10 | B_SMPTE_ 60_7k_4_1_-3_dBFS_44k_PCM16_LR_Dither.wav | IMD SMTPE | Input 24bits/192kHz, FFT length 512k, BH7, 32 Averages |
11 | B_TDFD_41_89_1_1_-10_dBFS_44k_PCM16_Dither_LR.wav | IMD TDFD | Input 24bits/192kHz, FFT length 512k, BH7, 32 Averages |
12 | B_Triple_9k_10k_20k_-10_dBFS_44k_PCM16_Dither_LR.wav | Tripple Tone IMD | Input 24bits/192kHz, FFT length 512k, BH7, 32 Averages |
13 | B_Triple_9k_19k_20k_-10_dBFS_44k_PCM16_Dither_LR.wav | Tripple Tone IMD | Input 24bits/192kHz, FFT length 512k, BH7, 32 Averages |
14 | B_Triple_10k5_19k_20k_-10_dBFS_44k_PCM16_Dither_LR.wav | OverSampling Filter attenuation analyzis | Input 24bits/192kHz, FFT length 512k, BH7, 32 Averages |
15 | C_Sine_100_0_dBFS_44k_PCM16_Dither_L.wav | Crosstalk @100Hz | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
16 | C_Sine_100_0_dBFS_44k_PCM16_Dither_R.wav | Crosstalk @100Hz | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
17 | C_Sine_997_0_dBFS_44k_PCM16_LR.wav | THD, THD+N with prime test tone | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
18 | C_Sine_997_0_dBFS_44k_PCM16_ShapedDither_LR.wav | High precision THD check | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
19 | C_Sine_997_-16_dBFS_44k_PCM16_ShapedDither_LR.wav | THD+N (to map with SACD Denon Test) | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
20 | C_Sine_997_-20_dBFS_44k_PCM16_ShapedDither_LR.wav | High precision THD check | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
21 | C_Sine_997_-60_dBFS_44k_PCM16_ShapedDither_LR.wav | Check dB gain in SNR with Noise Shaping | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
22 | C_Sine_997_-90_dBFS_44k_PCM16_ShapedDither_LR.wav | High precision THD and linearity checks | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
23 | C_Sine_997_-110_dBFS_44k_PCM16_ShapedDither_LR.wav | High precision THD and linearity checks | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
24 | C_Sine_997_-120_dBFS_44k_PCM16_ShapedDither_LR.wav | High precision THD and linearity checks | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
25 | C_Sine_1000_0_dBFS_44k_PCM16_Dither_L.wav | THD, THD+N, Crosstalk @1kHz | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
26 | C_Sine_1000_0_dBFS_44k_PCM16_Dither_LR.wav | THD, THD+N | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
27 | C_Sine_1000_0_dBFS_44k_PCM16_Dither_R.wav | THD, THD+N, Crosstalk @1kHz | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
28 | C_Sine_1000_-3_dBFS_44k_PCM16_Dither_LR.wav | THD, THD+N | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
29 | C_Sine_1000_-6_dBFS_44k_PCM16_Dither_LR.wav | THD, THD+N | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
30 | C_Sine_1000_-9_dBFS_44k_PCM16_Dither_LR.wav | THD, THD+N | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
31 | C_Sine_1000_-12_dBFS_44k_PCM16_Dither_LR.wav | THD, THD+N | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
32 | C_Sine_1000_-20_dBFS_44k_PCM16_Dither_LR.wav | THD, THD+N | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
33 | C_Sine_1000_-30_dBFS_44k_PCM16_Dither_LR.wav | THD, THD+N | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
34 | C_Sine_1000_-40_dBFS_44k_PCM16_Dither_LR.wav | THD, THD+N | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
35 | C_Sine_1000_-60_dBFS_44k_PCM16_Dither_LR.wav | THD, THD+N | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
36 | C_Sine_1000_-60_dBFS_44k_PCM16_LR.wav | DR (undithered) | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
37 | C_Sine_1000_-80_dBFS_44k_PCM16_Dihter_LR.wav | Linearity Test (Dithered) | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
38 | C_Sine_1000_-90_dBFS_44k_PCM16_Dither_LR.wav | Linearity Test (Dithered) | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
39 | C_Sine_1000_-100_dBFS_44k_PCM16_Dihter_LR.wav | Linearity Test (Dithered) | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
40 | C_Sine_10000_0_dBFS_44k_PCM16_Dither_L.wav | Crosstalk @10kHz | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
41 | C_Sine_10000_0_dBFS_44k_PCM16_Dither_R.wav | Crosstalk @10kHz | Input 24bits/96kHz, FFT length 256k, BH7, 32 Averages |
42 | D_JITTER34416.wav | Jitter Test (https://hydrogenaud.io/index.php/topic,108927.0.html) | Input 24bits/44.1kHz, FFT length 128k, BH7, 32 Averages |
43 | D_Sine_1000_-90.31_dBFS_44k_PCM16_LR.wav | 3 DC levels representation | Input 24bits/44.1kHz, FFT length 128k, BH7, 32 Averages |
44 | E_MT_Dec_20_20000_-10_dBFS_44k_PCM16_LR.wav | Multitone (1/10 decade) | Input 24bits/44.1kHz, FFT length 256k, BH7, 32 Averages |
45 | F_White_PN_128k_Full_-10_dBFS_44.1k_PCM16_Dither_LR.wav | OverSampling Filter response (up to 96kHz) | Input 24bits/192kHz, FFT length 512k, BH7, 300+ Averages |
