I'm happy with the SR8015 but I tried to set up 5ms and the bass is much stronger (Blade 4k / Atmos). I remember the Harman/Kardon AVR5500, the best sound i had. Today's receivers do not match its sound. Today I have HDMI inputs, more channels and sound modes but the sound is declining and the problems are growing.It doesn't make sense with an amp that can't handle. But when it's managed well, the payoff is absolutely "colossal". The fact of having a multitute of bass transmitters in line in front of you, confers a more homogeneous bass (less knots) in the piece, and a dynamic which never crumbles.
You won't, but if you're really curious, try an amp that has auto-phasing algorithm. And put your speakers in Large. You will rediscover your multi-channel soundtracks.
And anyway, the problem also arises if the speakers are small ... (since the problem lies in the delay of the low frequencies that there is in the input signal)
Sync/Basse (Bluray-Live)
(+-5 ms) :
Lee Retenour
Shakira
Stromae
Amy Winehouse (DTS-HD)
Calogero (DTS-HD)
David Foster
0 ms :
Destiny's Child
Ayo
This IS it
Adèle
Ben l'oncle soul (DTS-HD)
Chris Botti in Boston (TrueHD)
Hans Zimmer
i am using google translator
