This is an updated review of the Denon AVR-X6700H. I
tested an early production 6700H a few weeks ago and found lower than expected performance. Denon Engineering traced this to a faulty capacitor( or capacitors) used in the initial run of this AVR. I requested an updated unit which the company was kind enough to send me.
I have re-tested the DAC portion almost completely but for the amplifier I am just showing some of the highlights as the problem was not there.
EDIT: this is the serial number of the tested unit: DBCY032000007
Updated AVR DAC Measurements
The original AVR-X6700H returned a SINAD of just 87 dB which was well short of what the lower end models had achieved. I am pleased to report that this second unit nicely remedies that defect:
This catapults the 6700H into the coveted green category of DACs from formerly red status:
Initially I had some problem with dynamic range in one channel. I traced that to noise due to grounding. Upon unifying the Audio Precision chassis with that of the AVR that problem was remedied and performance is as good as before now:
IMD test shows the improved distortion:
Linearity improved as well:
As did filtering:
Distortion in lower frequencies in multitone are the same as before but at mid to higher frequencies, it is much better:
As expected, this showed up in THD+N versus frequency:
And here is our favorite new graph with THD+N versus output level:
Per requests, I turned up the volume so that we could go beyond 4 volts to see the response there for external amplifiers that are much less sensitive (green).
AVR Amplifier Updated Measurements
The amplifier did not change but improved grounding did make some things better. In Dashboard we are dominated by distortion so this remains the same:
But signal to noise ratio improved good bit:
Note that this is NOT due to the capacitor fix but rather better grounding of the AVR and measurement system.
And here is a power sweep showing that the one channel that was misbehaving before, no longer is:
Engineers struggle to improve system performance by 3 dB. Here, the proper capacitor resulted in whopping 12 dB increase in SINAD. That is a lot of performance to have left on the table. The AVR-X6700H goes from "hmmm? to "now this is nice!" with this component change.
Given the new performance,
I am happy to recommend the Denon AVR-X6700H. The company has a great platform here relative to its competitors and now you go up and down the models and not given up on the core value of it.
US is nearly one of its most important elections in decades. The panthers have been watching the election news with me and are demanding that I campaign for them to get the right to vote!!! I tell them this is not going to happen but they don't listen. They want me to make signs for them and go stand on street corners to protest. I figured it is easier to do that than to argue with them but I don't have the money for signs. Would you be kind enough to
donate what you can to make them happy using
