They are affected. I have a European model, I'm sending my unit to them to swap out the PCB with the degraded capacitors next week.Does someone know if the issue is/could also be present in the european models (AVC-X6700H)?
I'm still wrestling with the "musical" part of the sound. It there's a known formula for making the sound more musical? Why is Denon or other companies not using it? I read this all the time from the reviewers, Denon (in my case avr-x8500h) is not as good for the two-channel music listening when compared to Marantz, Anthem and Arcam. The same Sound United team in the mentioned video made me feel like I bought a subpar receiver since Marantz sounds "better" because it has better parts.
Doesn’t this prove with scientific measurement that capacitor can measurably affect SINAD by large amounts, assuming that Denon is honest about the capacitors (which I have no reason to suspect is untrue?)
Hi Peng, I just looked up the harmonic distortion for the 2nd & 3rd harmonics (90db,1m) of my speakers and it's listed as <0.4% 120Hz-20kHz. Question is, would my speakers be able to resolve this difference, and would my ears be able to hear it? I would think in the "normal" residential space with minimum room treatments, the listener would be bathing in all kinds of first, second and etc reflections which I would think would make it even harder to hear the direct sound.I wish they would just go with the numbers instead of such claims that are so subjective in nature. What sounds musical to some, if achieved by intentionally allowing some harmonics to provide the "sound signature" may not be to others.
In you search the internet for such talks, you will see that the 2nd and rd, more so the 2nd harmonics are responsible for the perceived "warmth". The counter argument though then, is that with THD+N lower than 0.01%, is it some easy for people to perceived such warm/musical characteristics even if the 2nd harmonic is in fact the dominant one? T is total, so if 0.01% is the threshold, even if there are only 2nd and 3rd that made up the 0.01%, how much would it matter?
You can compare the FFT of the Denon AVR-X8500H and Marantz AV8805 that shared lots of components and circuitry, and were launched the same year.
To my eyes, most of the harmonics were below -100 dB, the Denon actually has more 2nd harmonics than 3rd than the Marantz, in proportion only though so in a DBT, based on harmonic contents/profiles I just can't see how one can sound "warmer/musical" than the other.
Another factor that could give the different "sound signature" is of course Marantz adopted the slow roll-off filter whereas Denon appeared to have adopted the default sharp roll-off, but that would affect digital inputs and with sampling frequency below 96 kHz only, or am I wrong about this? At least for sure if in direct mode using analog inputs the two should sound the same, all else being equal.
Would love to hear from Amir's take on this.
If one doesn’t need 13 channels, or any of the other features of the 8500 (amp disconnect etc) the 4700 definitely sits in a nice sweet spot for price/performance-front hdmi, auro 3D, good power etc.If the price is the same I would take the 8500, say for up to $2,500. Otherwise I am more attracted to the 4700 because I thought their overall test results were very good and 7.1.4 is all my room can take unless I move but if I move again it would be to a smaller house.
yes yamaha rx-a3080 and cx-a5200I'd like to see some other brands tested personally. Teac, Integra, Yamaha etc.
I registered my unit with its serial number and proof of purchase on the support site. Then I opened a question against it.Very nice to get verified. Who did you contact to get your units serialnumber checked?
May I ask how you feel the 4700 compares to a 4500 available at nearly 50% its cost. Still worth the extra?If one doesn’t need 13 channels, or any of the other features of the 8500 (amp disconnect etc) the 4700 definitely sits in a nice sweet spot for price/performance-front hdmi, auro 3D, good power etc.
Yup. But this is nothing new. There are capacitors and there are capacitors. Anyone who claims that all capacitors are benign and cannot affect the signal is simply ignorant. But that has never been the problem with audiofoolery. The problem is when there are claims that some magical super special capacitor is audibly better than a known good capacitor. High-k ceramic capacitors have been known to exhibit distorting behaviour pretty much since the dawn of audio. There are specific places in circuits where they should never be used. They are, and always have been a known bad capacitor in these roles. Perfectly good, indeed preferred in other roles. The EDN article I linked to above is just one of many references to the problem. Doug Self's works on audio design is another place you will find such things discussed. Heck I first heard about it back in the early 80's when I built by first amp.Doesn’t this prove with scientific measurement that capacitor can measurably affect SINAD by large amounts, assuming that Denon is honest about the capacitors (which I have no reason to suspect is untrue?)
With the updated 6700 measurements included, I updated my comparison table. As always, this is just for quick reference. For accurate numbers please refer to the ASR reviews.
PCBs in almost every manufacturer have version numbers to keep track of changes out of logitics and inventory necessity. A component change would most certainly have a version number change on the affected PCB.Inspection of the PCB would be very unlikely to be of use. The capacitors in question would be tiny surface mount, and display little to no useful markings.
???Overall there is no reason to imagine the story is anything other than what Denon claim. An ingrained cynicism and desire to find fault and malicious intent seems to be part of modern society. Which is a great pity. It reflects more on those trying to find fault than anyone else.
@Francis Vaughan ’s post after mine explains this betterNot quite - this assumes Denon is being truthful, and if so, that a *bad* capacitor is at fault (not cheap). This is different to the audiophile 'fact' that better quality capacitors, even with the same capacitance are better. This is an electrical mystery to me, unless the 'low quality' capacitor is doing something the 'high quality' capacitor isn't.
Lastly- The infamous S/N from the your tested system. All I need is the last 3 digits... As I earlier mentioned, I had Denon level 2 support email me the (lot) last bad s/n and the start of the spec'd capacitor system S/N.
Please, please send us the (last 3 digit) tested s/n. If the system s/n falls inline with Denon's email. I will release the email to everyone.
