Artsfols
- Joined
- Mar 24, 2021
- Messages
- 204
- Likes
- 156
Tried the most settings and various configs. I will start with the 4-5), yes, it turns the bass down a bit, so I can undestand, what it does. As for 3) I use it at 0-5dB setting and you are absolutly correct, that with 2) (Dynamic volume), set to Light, it seems that it opens-up.
When one of my friends visited me (he owns a Marantz), he switched my Denon to Pure on a remote and turned up the volume. Denon got quite quiter, in comparison, what we normally run at 30-35, the same level of loudness was delivered at 50-55 in Pure / Direct mode. He called my Audyssey settings a gimmick
On the other hand, ppl do various stuff. Some suggest to limit Audyssey to 500-700 Hz range, some suggest to trun-off midrange compensation in the app, etc., but then I have seen the interview with the Denon rep and the Audyssey author, who did not suggest that
I found your note re subwoofer quite interesting though. I thought, I might not necessarily need it, as MA S200 are a good speaker, though some find them being a bit bright. Ppl suggested me to go with Rel or SVS, but if I would be supposed to get sub, it would be the Silver line W-12. I just would need to prepare my wife for a big box joining our family So - is the "trick" that sub would help the speakers to offload the bass to the sub, by setting some cross-over value? Would that help Denon / the rest of the speakers, to provide better performance / balance?
Thanks,
/Petr
Forgive me if I missed an earlier post, but what's your reference point for saying the stereo sound is not as good. Did you replace an earlier model stereo amp? What was it?
And also did you recently add or change the television? I'll relate an experience I had. Replaced an 'on the wall' plasma display with an new 65 inch LG OLED panel sitting on cabinet between the speakers. After about a year I put that new panel back on the wall. (There were reasons for the delay but I won't bore you with that). The stereo imaging with the panel on the wall compared to on the cabinet is like night and day ... way, way better. The panel on the cabinet was killing the backsplash on the speakers, some of the highs and the imaging in general. Of course, this situation is not universally applicable but it's something to consider.
In general, I would be looking at other factors than the amp. Did you have surrounds and/or centre before? And how would those changes play into what looks like a bright room with lots of reflective surfaces.
Your situation has made me curious because I've just ordered a new X3700H AVR and a centre channel to upgrade my "purist" stereo set up. I'm not actually a purist, but I do like the stereo sound I have now and don't want to spend $X,000 for a step backwards. If I can keep the same sound quality playing SACDs and CDs, I'll be a happy camper. The AVR purchase is to provide better handling of digital streaming sources.
