3700h Owner here who ‘upgraded’ from the 3600h.
So I had the unit for a month now, and currently in contact with Denon support over my issue which is now 100% confirmed after following Denon customer support advice to unplug/replug/rest unit.
The issue: the 3700h is not as powerfull as the 3600h, most noticeable in the subwoofer, sub also lacks the tight impactful bass that it’s predecessor had, 3700h is more sloppy and boomy. All other equipemnt (speakers) are the same, this was a simple swap out.
the detail: I noticed right away during audysyss set up, the test tones didn’t play with the same loudness and impact as the 3600h. Both units asked me to set the sub amp gain knob to the same point, but after calibration finished the 3700h set my sub to -1.5db (done this many times) where as the 3600h would always set it to -6db, this tells me that the pre out for the sub is nowhere near as powerfull as the 3600h is. I keep the sub behind my sofa and the 3600h had my sub kicking me in the back on music, a nice deep bass that I can feel but not hear (not muddying the sound of the front) the 3700h is opposite, even after I turn the sub level to +5 to get same level as the 3600h the sub lacks the tonal quality the 3600h had, it’s more boomy and muddy, I.e. I hear it too much and feel it not enough.
has anyone else noticed this coming from the 3600h to the 3700h? I’m regretting I ever upgraded now.
edit: when I go into menu/speakers/Audyssey setup/check results/eq/reference I’m fairly sure I was able to see the curve for the sub before on the 3600h but I can’t on the 3700h or am I mistaken?
