Well, I'm interested in the Parasound P6 myself as it matches my speakers and amp well (and I love the HT bypass and analog bass management functionalities). But I don't have measurements at hand - I can only say I demoed it at my house and it is night and day difference vs the X3700h.
I would be able to get full power from my amp (A21) while the X3700h does not.
And what is full output then? I highly doubt that 2 V will not be enough.
That doesn't sound right. The A21 is only rated 250 W 8 ohm, 400 W 4 ohms. The X3700H has more than enough output voltage for the A21 to reach its rated output.
Here is what Amir had mentioned in the review:
As you see, peak performance with the amplifiers off is around 1.1 volts with SINAD of 101 dB which is excellent for an AVR. With the amps on, you are OK up to 1.4 volt output before it nose dives. So when selecting an external amplifier for channels beyond fronts, make sure it can output its maximum power at or below 1.4 volts (usually specified as "sensitivity").
By my back-of-the-envelope calculations, one needs in excess of 1.58 volts to get full power from the A21. [sqrt(250*8)/28.28]. Even in case of all amps switched off, the 3700h preamp module SINAD goes down quite a bit at the necessary preamp output voltage levels.
Additionally, using a preamp like the P6, I can run A21 in class A (as opposed to class AB) mode upto a higher wattage level than if I were to use the 3700h.
https://www.audioholics.com/editorials/denon-marantz-firmware-updateI just turned on my 3700h and it has a firmware update ready to install. I installed the update but could not find any release notes. Do you know if denon posts the release notes of firmware updates
Don't forget you can disconnect the front left and right channel if you are using the 3700 for two channel stereo.
The A21 is only class A (sort of) up to about 8 W at the most so the 3700 will have way more than enough output for that if that's what you are concerned about.
Also, you are aiming for 101 dB SINAD? I don't recall seeing any (may be I missed one or two?) preamp ASR measured could to that, DAC, headphone amps, yes but not full blow preamps like the P6. May be it could do it but I doubt it very much. Hopefully someone will send one in.
I set up Audyssey in preamp mode with an Anthem MCA 50 5 channel amp.Another issue (perhaps, naturally so) I have with the x3700h is that I cannot use Audyssey in preamp mode. Only way to do so is to switch on internal amps (thus worsening SQ even if I’m using A21 and no internal amplification).
I asked this question over at AVSForum (because nobody had replied to me here).
This is jdsmoothie's response: "If you change the AMP ASSIGN setting after running Audyssey, then Audyssey is usually disabled until Audyssey is run again under the new AMP ASSIGN configuration. More than likely that person failed to run Audyssey again after selecting the Pre-Amplifier mode. You can confirm Audyssey is active simply by pressing the INFO button on the remote."
I have only used my 3700 in preamp-only mode from day one, and set up Audyssey in preamp-only mode with no issues.
Good luck!Thanks. I shall try that. Am optimistic!
Good luck!
Ask your question over on AVSForum 2020 Denon AVR thread.Did not work. Perhaps, because I’m sending the data from iOS’s Audyssey MultiEQ app?
Basically, before sending the data, I verify that ‘Preset 2’ is in Pre-amp mode. After sending the data to preset 2, it is no-longer in pre-amp mode. And, when I change preset 2 back to pre-amp mode, I cannot use the Audyssey correction anymore.
Tried resetting the receiver twice but to no avail.
