DonR
Different dialects.I do not understand why some people cannot speak/spell simple English.
Translation: stand in line at Krispy Kreme donuts asking for 1 dozen mixed donuts for take-away.
Different dialects.
I find old Paul Hogan shows totally unintelligible.Thankyou, you are too kind. A bit like how I cannot understand a lot of the dialogue in the movie A Clockwork Orange.
Professionel view on cable risers,lifters
They are basically telling you they "heard" differences (Paul says only in speaker cables).Can you summarize each of those, so we aren't required to watch them to get an idea of what they are trying to say?
We are trying to move away from video links with no TLW summary we can work from. Too much nonsense out there to wade through.
No need to watch videos on the subject - it is simple enough for anyone to test themselves. Put something with a low dielectric constant and low permeability under the cables to lift them off of the floor and listen for any changes. Somebody herein mentioned using plastic cups, and someone else mentioned wood blocks. Either of those should work pretty well.They are basically telling you they "heard" differences (Paul says only in speaker cables).
Irony, sarcasm and the intrenet.Professionel view on cable risers,lifters
It was good that you pointed that out. Maybe not unusual with RF interference via speaker cables, but with other cables, let's say poorly shielded RCA cables, it can absolutely be a problem. The risk increases with long and unshielded RCA cables. I know you know this but it's worth mentioning anyway when it is sometimes said on ASR that cables have no audible effect on the sound whatsoever. That is a truth with modification so to speak. Or what is it called in English? A truth with a caveat? Or adding a caveat?Serious comment - If moving cables around makes a difference you've probably got a bad cable (unshielded, or a broken ground, etc.) or some very strange-unusual problem. And if moving the cables makes a difference "raising' them could make the problem better or worse.
With speaker cables it should never make a difference unless some RF interference is somehow getting fed-back into an amplifier that's sensitive to that (very-very rare). Generally, speaker cables are immune to noise (or any other effects) and you can't pick-up enough electromagnetic noise to make sound from a (passive) speaker.
An exception could be phono cables near a transformer where any hum picked-up will be amplified about 1000X by the phono preamp. And if you hear hum you'll know it and you can just experimentally move the cables and you probably don't need to "raise" them to get them away from the noise source.
audiosciencereview.com
It was a joke.No you don't. They are AC, so you would not be saying such things if what you said was true.
They do make a difference, not with all speaker cables but only with speaker cableCan you summarize each of those, so we aren't required to watch them to get an idea of what they are trying to say?
Mixing doughnuts courts disaster, what we are looking for is a uniform doughnut loom, avoid the sugar coated ones though attracts ants.Different dialects.
Given some of the responses to your posts, @Purité Audio I feel inclined to mention the bon mot attributed to George S. Kaufman:I have been reading subjective reviews for forty years, are you saying they are all charlatans!
Satire is what closes on Saturday night.
It was a joke.
However whether the cables are passing AC or DC is irrelevant. With enough current, the cables could heat up regardless.
Seriously this is so funny, please I think you are on the wrong forum!Cable raisers
Some say it makes a difference,some say they don't
If you,i wanna try something cheap, what can we buy that doesn't cost a furtune ?
Do they make a difference ?
5-6 euros for 10 (on your floor panels or floor View attachment 376746 )
7 euros for 6
Indeed, the cheap ones sound ******
I did put a ;p at the end of the sentence. For some reason it didn't display as an emoticon.Clearly you have a wet sense of humour. What is the point of saying things that are not only untrue but dangerous to the naive? Just one reason. No excuses.
What next bells
That is not a valid test as you are not controlling any of the variables that matter. i.e. your bias.No need to watch videos on the subject - it is simple enough for anyone to test themselves. Put something with a low dielectric constant and low permeability under the cables to lift them off of the floor and listen for any changes. Somebody herein mentioned using plastic cups, and someone else mentioned wood blocks. Either of those should work pretty well.
Step out of the room, put on a blind fold, have someone move the cables for you, then have them lead you back in when you are ready to listen. Repeat.That is not a test as you are not controlling any of the variables that matter. i.e. your bias.
