Noske
Is Godddammit coming close to using a profanity? Settle down.Goddammit Noske is your intention to single handedly undermine the whole hi-fi industry!
I've used little red plastic cups turned upside down and clear acrylic napkin rings turned on their side. If I still had need, I'd consider these:If you,i wanna try something cheap, what can we buy that doesn't cost a furtune ?
Don't you find that the maple glazed sweeten the sound more?I use Kristy Creme doughnuts the plain glazed with holes, obviously.
It was a humorous comment by @Purité Audio I thinkIn audiophool land - and it appears especially in the far eastern audio markets, the price tag is EVERYTHING in high-end audio, irrespective of what goes on inside (or not, as the case may be). I was told once by a small maker that more than doubling his selling price for a valve based phono stage he made, actually brought about more sales due to the perceived value being increased as it was judged too cheap before.
Here in the cash-strapped UK, a few makers try to keep a local high end industry going, but they often get found out when properly rigorously tested, so don't usually get their products properly reviewed. Only the 'influencers' around and about 'spread the word.'
Back to topic, I don't think cable risers have made any inroads here apart from maybe one or two die-hards![]()
Everyone knows the Cinnamon ones give better bass responseI use Kristy Creme doughnuts the plain glazed with holes, obviously.
One actual use case might be where a power cable is imbedded in the floor beneath and is electromagnetically coupling with the cable. Separation in that case will be helpful but the choice of material in the standoffs is irrelevant.Serious comment - If moving cables around makes a difference you've probably got a bad cable (unshielded, or a broken ground, etc.) or some very strange-unusual problem. And if moving the cables makes a difference "raising' them could make the problem better or worse.
With speaker cables it should never make a difference unless some RF interference is somehow getting fed-back into an amplifier that's sensitive to that (very-very rare). Generally, speaker cables are immune to noise (or any other effects) and you can't pick-up enough electromagnetic noise to make sound from a (passive) speaker.
An exception could be phono cables near a transformer where any hum picked-up will be amplified about 1000X by the phono preamp. And if you hear hum you'll know it and you can just experimentally move the cables and you probably don't need to "raise" them to get them away from the noise source.
I run my speaker cables through water to keep them cool. ;pCable raisers make no difference to anything, unless you perhaps have wet floorboards.
Well… kinda, sort of…to a degree…I have been reading subjective reviews for forty years, are you saying they are all charlatans!
Even better for easier cleaning and I think it looks nicer when it is done like this with the cables:They work great, for easier cleaning. ....
Cable raisers
Some say it makes a difference,some say they don't
Do they make a difference ?
5-6 euros for 10 (on your floor panels or floor View attachment 376746 )
7 euros for 6
Or in line at Kk saying 1dz mixed to go, pls!The moderators must be offline.
Or in line at Kk saying 1dz mixed to go, pls!![]()
