GabrielPhoto
- Joined
- Jul 14, 2020
- Messages
- 512
- Likes
- 309
So I was cleaning of my wiring and decided to test some cables for noise floor, hum etc.
With my gazillion connections I do get a faint hum on my subs if I remove the jensen ISO-MX that gets rid of it, so I figured that would be a good way to test RCA cables to see if any make a difference.
Well turns out they do change the level of that hum substantially.
Some were about 4db louder than the best.
For example, a WBC was 2.5- 3db louder than the best cable which turned out to be a SKW cable which on top of that was the longest at 16.5 vs 12' for the others or so. Basically with the SKW the difference between the hum with and without the was about 1 db.
Other surprisingly not so good cable was the Mediabridge which I have been recommending and using often.
I recall SKW being pointed out about their copper purity or something like that so I am surprised that so far it was the best of all I tested. lol
I have a Silver Serpent cable I am planning to test to just for kicks.
In any case, it was a curiosity test while cleaning up my wiring and was not expecting much if any differences.
